Rolling Shutter - Page 3 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old March 26th, 2008, 06:39 PM   #31
Originally Posted by Chad Dyle View Post
These clips were shot monday night at a church I shoot at all the time. The camera was set to manual, but focus was set to auto. The Iris was on manual as well. The blurring seemed to be at the same distance each time a bridesmaid /groomsman would walk towards me.
http://www.chaddyleproductions.com/2...t/Blurring.wmv
Chad...............
Did you do a back focus on the camera when you first got it?
Ryan Lester is offline   Reply With Quote
Old March 27th, 2008, 06:05 AM   #32
Ryan,
I was told that I didn't have to adjust the back focus unless I had problems. This was the first problem that I have had with the camera. I did read a little about setting it up and its going to be the next thing that I try.
Chad Dyle is offline   Reply With Quote
Old March 27th, 2008, 06:47 AM   #33
Chad, checking backfocus is easy, on all my pro lenses you simply setup a test image
http://www.dsclabs.com/
http://www.bealecorner.org/red/test-patterns/\
zoom in and focus...zoom wide and if out of focus (manual focus)
loosen the backfocus screw and adjust
p.s. shoot wide open and Don't over tighten( I onced cracked my back focus ring on a jvc-3)
also a long time ago on a old tube camera my backfocus screw loosened up on me and didn't realize untill 10 minutes later, so it is good to know where that adjustment is and check occasionaly
any chance of uploading footage with multiple flashes going off
thnx steve
Last edited by Steve Gerhart; March 27th, 2008 at 11:11 AM. Reason: added link that is advertised on this web-site
Steve Gerhart is offline   Reply With Quote
Old March 27th, 2008, 04:32 PM   #34
Ryan,
Yeah...... the lens comes attatched so i would have assumed that you didn't have too............ but it's worth trying anyway.
Edit:-
Oh........ and i'm pretty sure that a test pattern comes with the camera..... did yours?
Last edited by Ryan Lester; March 27th, 2008 at 04:34 PM. Reason: forgot to add something
Old March 28th, 2008, 06:50 AM   #35
Both of them came with the test pattern. A previous post suggested that I should remove the UV filters and see if that helps. We have 5 weddings this weekend, so I'm gonna give that a shot. I'll keep you guys updated on what happens.
Old April 1st, 2008, 10:03 AM   #36
thnx steve
That looks like the autofocus went haywire, has nothing to do with back focus.
Khoi Pham
www.proeditproductions.com
Khoi Pham is offline   Reply With Quote
Old April 1st, 2008, 03:13 PM   #37
Hello,
There is no backfocus ring on the Z7 lens to adjust the backfocus.
We have just to focus in tight shot then adjust the focus in wide shot.
It's clearly impossible to adjust a focus on the shorter focal lenght because the focus stands still from 2m to infinity... So the auto mode seems to be the more appropriate.
On my own experience, I 've never achieved a correct back flange on my Z7, using manual or auto mode.
Arnaud Keil is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
