To Sell HDV filmed by Z7 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old March 10th, 2008, 12:43 AM   #1
Is there any way to convert HDV to full HD; will I be able to sell my footage/film to ANY TV station/studio etc. or they will require at least entry level CineAlta Ex1
Marius Boruch is offline   Reply With Quote
Old March 10th, 2008, 03:54 PM   #2
Master to HDCAM, and don't tell them where it came from. That's what I plan to do.
http://www.prolefeedstudios.com/blog/
Documentary for the masses!
Brian Standing is offline   Reply With Quote
Old March 10th, 2008, 04:17 PM   #3
Saw this tonight in a thread in the EX1 section.
Originally Posted by Greg Boston View Post
Michael, Sony's official view is that there are 3 tiers in their product offering for HD.
HDCAM/SR is high end
XDCAM HD is medium level
HDV is consumer/prosumer
However, early on with XDCAM HD, it was the opinion of most who saw the quality of images, that XDCAM HD is not squarely in the middle, but closer to the top end. The higher data rate removes a lot of the motion artifacts that can plague HDV. It's not the inter-frame compression of long GOP at fault, it's how much compression and how intelligently it's applied that determine the outcome.
I wonder what this stock HD firm will say about the PDW 700 with its 50mb 4:2:2 color space. If they try to call that image less than HD, they are nuts.
Also a reminder, Discovery HD has one of the most rigorous acceptance criteria for HD and they certified XDCAM HD @ 35VBR as acceptable for unlimited content acquisition, whereas they limit HDV to no more than 15% of a given program.
All is not lost though, at some point, you'll have the ability to strap on a portable flash recorder and take the HDSDI feed into a very high quality codec.
-gb-
Old March 12th, 2008, 08:48 PM   #4
I have a chance to buy Canon G1 with HD-SDI and I was wondering if you have any recommendation re: portable HD-SDI recording unit so I could record to the unit directly in the field...
take a look at this http://www.kinor.ru/products/flashdvr/
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
