24P Jerkyness? - Page 2 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old March 3rd, 2008, 12:20 PM   #16
24p judder
If your interlaced camcorder is using a pseudo 24p method of recording, then you might need to deinterlace with software like JES_Deinterlacer. Once dienterlaced, you can then edit the files as 24p in your NLE of choice.
Check this video: http://www.vimeo.com/727203
It was shot in 24p (Canon's version), deinterlaced, then edited on a 24p timeline in FCP.
There is not much panning, but the movement looks smooth. You can also view this video: http://www.vimeo.com/697638. Looks pretty smooth.
You can also try shooting in 30p for less judder, but 60p is the schnizzle when it comes to smooth progressive shooting. Otherwise, just shoot interlaced.
Yeah, the "film look" is sooooo 20th century. I prefer the "video" look.
John Markert is offline   Reply With Quote
Old March 4th, 2008, 02:19 PM   #17
30p is also good in that you can mix 60i and 30p without worry.
There are basically two problems with 30p:
1/ It doesn't convert to 24p for film release well.
2/ it doesn't convert to PAL well.
Most PAL DVD players play back 60i or 30p just fine, but if you are interested in broadcast in a PAL country, you shouldn't shoot at 30p.
Laurence Kingston is offline   Reply With Quote
Old March 9th, 2008, 08:29 AM   #18
So what do you recommend for shooting weddings? 24p or 30p?
Ed Molina is offline   Reply With Quote
Old March 9th, 2008, 09:13 AM   #19
John,
What program did you use to convert/embed that video with? I really like the interface. I've been using a cheap $35 program I got off the web, but I'd like something better.
Chad
Chad Dyle is offline   Reply With Quote
Old March 13th, 2008, 03:43 PM   #20
JES Deinterlacer for Mac. SAved to photo jped. Edited on a 24p FCP timeline.
Old March 16th, 2008, 01:26 PM   #21
Space Hipster
It's a great thing to have but it's been somewhat over-marketed.
That's like saying "film" or "video" or "color" is over-marketed.
People have been making and watching 24 fps films for nearly 100 years. I hardly think it's a "feature" or "option". For many motion image creators, it's a requirement to tell stories with moving pictures. There is big difference between "great" and "requirement".
60 (50) fps has its place for situations that require it (and maybe 120 fps in the future) but as of right now, the use of 30 fps and faster frame rates for narrative, documentary etc. is decreasing not increasing due to the availiability of low cost 24 fps production. I've noticed a real decrease in interlaced production on low-end docs.
The HV20 is the shining example of this.
Per this thread, if you have not shot 24p before, I highly recommend going to see a film in the theater that you are not interested in and just watch motion, camera moves. Then hopefully watch the same movie on a TV with pulldown etc.
Learning to develop an intuitive sense of bad panning, tilting, zooming speeds is important as is knowing how to follow a subject in a frame so that the artifacts of 24p are not an issue. Don't forget that with 1/48th shutter, certain fast moves can work well as well - it's those intermediate pan and title speeds that can get you in trouble.
ASC guidebooks etc. have some good info on precisely measuring this for various formats.
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline   Reply With Quote
Old March 16th, 2008, 01:32 PM   #22
Space Hipster
That makes no sense. If it was shot 24p, there is nothing to de-interlaced. The
"p" stands for progressive. A deinterlaced filter with probably do nothing or soften the video and perhaps do something weird to the pull-down.
You should know I started a very long thread here years ago talking about "film look" vs. "professional" look.
So, you need to define what you mean by "film look" - frame rate, color rendition, latitude, resolution, grain, lighting, camera work, production value or other.
These are actual all separate items and cannot be lumped together. Of course, my argument in the old thread was frame rate is the most important aesthetic factor in determining "look".
stephen v2
Old March 19th, 2008, 01:16 AM   #23
i was just reading this out of curiousity to see how this ended and felt i had to butt in for a sec. sorry.
Stephen i think John mean't he removed the 3:2 pulldown out of the 60i footage. because the Canon HV20 records 24p onto a 60i timeline with a 3:2 pulldown. correct? so i imagine by saying he deinterlaced was the same as saying he removed the 3:2 pulldown. then making it truly 24 progressive.
Forrest Schultz is offline   Reply With Quote
Old April 6th, 2008, 07:20 PM   #24
I wonder how much digital projection will change the aesthetics regarding frame rate on motion pictures...
I think 60p with 1/120 shutter looks way cooler and hyper, better suited for a crazy action movie than 24p, that otherwise may work very well for a slow paced drama.
24p was born as technical constraint and professionals made a good use of a bad thing. Maybe in the soon future new professionals can make good use of new elements.
Just like we choose what aperture to use, which angle to frame from or how to light the scene, we'll choose the frame rate of our movie instead of being stuck with only one option.
Pietro Impagliazzo
flickr.com/photos/impagliazzo
Pietro Impagliazzo is offline   Reply With Quote
Old April 16th, 2008, 04:58 PM   #25
Well, unlike most opinions in this board, I don't view 24p as a simple fad. Allow me to argument my view.
I am well aware that the 24 frame per second cadence was established in the early days of the movie industry as the "minimum common denominator" between movement fluidity and film economy. It's the slowest FPS ratio that allows for a fluid perception of motion, thus allowing filmmakers of the day to save miles and miles of film.
Nevertheless, we have grown accustomed to associate that very 24FPS cadence with film narrative. For over a century the 24fps has become a staple of how we understand storytelling in movies. Just to prove it, compare any scene from a Hollywood movie (shot in 35 mm film at 24 FPS) with a similar scene from a soap opera (shot on interlaced NTSC at 29.97 FPS). Your perception of those different scenes is very different.
The 24 FPS film scene is understood as narrative, part of a story, and even "expensive" if shot well. The 29.97 interlace scene is subconsciously perceived as "fake", a "live feed" and even "cheaper" in certain circumstances.
Those perceptions have nothing to do with the quality of the images, but what we have grown used to. This is less related to the specific technology we use, but rather the industry conventions that have been used for over a century. For many decades we have seen movies in 24 FPS film, and television on 29.97 interlaced. Our brains have been accustomed to this language. If Hollywood had adopted 30FPS instead, our association would have been different. In short, the cadence of movies has become a part of the narrative itself, a part of the aesthetics of film storytelling.
One of my film school teachers said that the 24 FPS motion looks and feels different, as it somehow resembles the "motion of dreams" in our collective subconscious. I really like that analogy.
I have shot on film (mostly 16mm, but some 35mm), NTSC video, and now HD. From my personal experience, I get a much more consistent look and feel for my narrative productions when I use 24p, because it replicates that 24 FPS cadence we so strongly associate with movies. If I shoot the same in interlaced NTSC, the perception of the same material is automatically understood as something else (news report, live feed), but not a narrative piece.
The same goes the other way around. If I shoot material for a news report in 24p, it automatically loses its perception of "live event" or sense of immediacy. It feels like something belonging to a story of fiction, not reality.
I am well aware of how quirky and cumbersome the 24p video workflow can be, especially with some HD formats. Still, I wouldn't use any other frame rate for a narrative production, even if it's not intended to be transferred to film.
Just my two cents.
J.B. Soler is offline   Reply With Quote
Old April 16th, 2008, 05:29 PM   #26
Although I really dislike 24p I see your point of view. The problem I have is that I do not mind watching film in a cinema that was shot on film with film technique and then projected properly by a professional projector that is likely to flicker at 72hz or greater. The issue I have is 24p on video, shot with poor technique( like one would shoot interlace video with too much pan movement etc) then somehow transposed into a 60i interlace stream for broadcast after being encoded for transmission down a cable is awful!!! Most progressives displays do not deal with 24p correctly so even coming from a DVD player that correctly delivers 24p, the original 24p image is corrupted into a juddering mess by various scaling,pulldown and interpolating circuits. Until there are displays that correctly emulate a film projector and a delivery mechanism is in place to correctly deliver that stream I for one will dislike 24p intensely because it is making my TV viewing terrible. Done in this fashion I believe it is a fad for people who want to be part of the film image but are not prepared to follow through with all the implications of this trend. If you shoot for broadcast television that will be distributed at 60i then shoot that way.
Ron Evans
Old April 17th, 2008, 08:40 PM   #27
HDV Cinema
Ron has presented a good information about 24p:
1) 24p was the frame-rate that allowed the minimum amount of film to be used that moved film with an optical track thru the sound head at a fast enough speed to allow frequencies up to 10kHz to be recorded.
2) A film frame is flashed on the screen because there must be time for the claw to yank another frame into the gate.
3) Humans will see BRIGHTNESS FLICKER unless the flashes occur AT LEAST 48Hz. Therefore, the same frame is flashed at least twice. Hence a 2 bladed shutter. This has NOTHING to do with creating smooth motion. Motion is created by the frame-rate which can be as low as 16 fps -- in fact, modern silent pix use 18 fps.
4) "flicker fusion frequency" is a function of brightness. 48Hz is the minimum. As projector's got brighter lamps, the increased brightness raised the FFF as so people saw flicker -- especially in bright skies. This is very EZ to see in PAL with TVs that display at 50Hz. So, 3 or 4 bladed shutters were used to raise the PRESENTATION rate to 72Hz or 96Hz. (Modern PAL TVs use a 100Hz presentation rate.) Again, this has nothing to do with creating motion.
5) HOWEVER -- it turns out that the presentation-rate can create "Foreground eye-tracking strobing." This is an eye-brain experience that is at its worst when the PRESENTATION rate is 2X the frame-rate.
The eye follows moving objects. It calculates the rate of motion so it EXPECTS the object will be in a certain positions. But, when the second flash of the SAME image occurs -- the eye has only moved half the distance to where it expects the new position should be. When the eye-brain sees 2 of the same objects slightly apart, you see strobing.
Guess what -- when 30p is displayed -- each image is PRESENTED twice. So shooting 30p or 25p -- you may be unhappy with the results.
6) With 60p HDTVs, 24p is presented WITH 3-2 pulldown. YES -- you do NOT see 24p!!!
The only way you'll ever see 24p at home is with a display that runs at 72Hz, 96Hz, or 120Hz!!! (Plus, a 24p connection from a BD player and a disc burned at 24p.)
7) Why then, shoot 24p? TO TRANSFER TO FILM!
8) But what if I want my video to look "less like video and more like film?" The simplest way is to use 25p or 30p. But, you'll need to know the rules of shooting low temporal rate media to minimize Foreground Strobing.
9) But I WANT 24p! OK -- you have two recording options. Pure 24p -- either 720p24 to tape or non-tape -- or 1080p24 to non-tape (except for the Canon XL-H1). If you shoot tape, you get 24p with 3-2 pulldown yielding 60i.
10) If you shoot 1080p24/60i -- you'll need to remove pulldown before editing in a 24p Timeline. But wait you say -- if I'm always going to see 24p with pulldown on my display, why do I need to remove pulldown before editing. Because if you don't -- when you edit you'll BREAK and MIX the 3-2 cadence.
Steve Mullen is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
