PP Settings to match bloom on ex1 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old February 29th, 2008, 01:16 AM   #1
Does anyone have a close setting to philip blooms settings on the EX1?
I am trying to match these closer, to get a deeper out of camera look, for both.
Also, would need settings for an FX1...
George
George Sickler is offline   Reply With Quote
Old February 29th, 2008, 03:07 AM   #2
He uses one of Bill Ravens PP's I believe, however it's often worked over in Magic Bullet before it "goes to print" so to speak. If you read his blog thread on here you should be able to find out which one he's using, but it looks to go through a decent amount of post so don't expect to get what he's getting right off ( you may have already known that as I'm relatively new here and don't know who's who ).
Dave
David Hadden is offline   Reply With Quote
Old February 29th, 2008, 03:45 AM   #3
Phill's also normally using a 35mm adaptor like in the picadilly short, and as you said, there's alot of post going on
Jamie Allan is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
