Outputs? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old November 29th, 2007, 07:51 PM   #1
Outputs?
Is there a list of outputs on these cameras?
I saw a glossy-type write-up that says the output is HDMI only, but then I see talk here of iLink, which is Sony's name for 1394 firewire, right? [Sorry, I'm new to Sony.]
What do you do with HDMI out besides connect it to an HDTV? Editing PCs don't have HDMI input jacks, right?
Jaums Sutton is offline   Reply With Quote
Old November 29th, 2007, 10:41 PM   #2
HDMI out is uncompressed Full res. 1980X1080
You would have to add a card to your desk top computer.
http://www.blackmagic-design.com/products/intensity/
Old November 30th, 2007, 02:47 AM   #3
They both have iLink. All you need to know at http://www.sonybiz.net/res/attachmen...3315642481.pdf
Hedley Wright is offline   Reply With Quote
Old November 30th, 2007, 08:43 AM   #4
I don't want to hijack this thread but I'm new to capturing via HDMI.
I'm assuming that in order to capture using HDMI that the camera needs to send the signal to the compute WHILE shooting.
Is there any way to finish the shoot and then capture via HDMI or do you always capture to the computer while shooting?
Kevin Crockett is offline   Reply With Quote
Old November 30th, 2007, 08:43 AM   #5
Thanks for the responses!
The brochure is for the "E" [European?] version rather than "U" for United States--does anyone know what differences there will be?
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
