Sony HVR-Z5U Cassette & Focus Repair - Page 2 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old May 11th, 2015, 07:51 PM   #16
Re: Sony HVR-Z5U Cassette & Focus Repair
Well, screw me. I think I had the gain on auto mostly. I got it back with alot of factory resets & that was one I hadn't changed. I rarely touch it anyway, and its been a while so I just thought not seeing any gain displayed meant it was 0. Before the LCD would display the gain (-12, -18 etc) when in Auto mode but it doesn't seem to do that now. Not even when the camera is in Complete Auto. Had I seen -12 displayed or whatever I would have known to change the gain to Manual but i didn't see it.
Upsetting as I reviewed over the camera. I suppose it could have been worse.
David Barnett is offline   Reply With Quote
Old May 11th, 2015, 11:11 PM   #17
You don't have to change it to manual -- you can set the upper limit so it helps but doesn't produce any grain.
I'm good with an AGC limit of 9, but fussier folks prefer 6.
Also note you can save your settings to a stick as a Camera Profile and just restore them when the cam comes back from the shop -- sort of like a Win SysRestore.
IIRC when a value isn't displayed, that usually means the cam is in auto mode for at least that value. It usually lights up when you go Manual, at least with most recent Sonys. I could be wrong -- I set my default preferences years ago and haven't changed them much since then. I'm pretty sure you can specify this behavior in the DISPLAY SET menu. Page 82. An "A" appears when in auto next to the data. You tell it whether to display cam data. Don't confuse this with DATA CODE, p. 54, which is for playback only, or DATE REC (p. 94) which burns the date and time permanently into the picture.
Old May 12th, 2015, 08:41 AM   #18
Thanks for your feedback Adam. I really thought the prev settings did show gain, as sometimes I saw some awkward settings, even like -3 outdoors in daylights?! with it having ND filters on 1/16 or 1/64 etc.
Anyway it was a short ceremony, although being at a venue the backdrop was black:( which really shows the gain. The dance floor was pretty well lit so that footage is ok. Not the end of the world, plus I think computer monitors don't show black as well as TVs tend to, and with Neatvideo & adjusting black levels it's passable.
Live & learn.
Old May 13th, 2015, 12:12 AM   #19
Yes, you aren't remembering wrong -- it *did* likely show gain, and it will again if you tell it to.
Page 82. Really.
Adam Gold is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
