Steadyshot "Hard" setting safe for brides entrance? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old September 19th, 2014, 10:08 AM   #1
Hello all, I use an FX1 handheld exclusively for the brides entrance down the aisle. My FX1000 is on a tripod and ready to go after she is delivered, the FX1 then becomes a backup camera for the day. I googled and learned a little about the Steadyshot settings. My questions is:
Could I see an improvement in my camera shake by setting the Steadyshot setting from Standard (currently) to Hard? Any pros and cons about using the Hard setting?
I hold as steady as possible, using eyepiece, and is most noticeable if I need to move a couple feet away.
Thanks all.
Darryn Carroll is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
