MIRC1 problem at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old June 20th, 2013, 10:20 AM   #1
MRC1 problem
I have a MIRC1 that recently stopped recording from the cam start button. It will record pressing the start button on the unit but is apparently not getting the signal to record from the cam. Have tried it on several cams with same result so have isolated the problem to the unit and not the cam. I gently cleaned the contacts to no avail.
Anyone experience this problem? If so, were you able to repair yourself? At $750 a pop for new unit I would like to get repaired if cost is reasonable.
Tom Mussatto is offline   Reply With Quote
Old June 20th, 2013, 05:58 PM   #2
Re: MIRC1 problem
i'm presuming you've gone through the various menu settings on both camera AND mrc?
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old June 20th, 2013, 07:04 PM   #3
Re: MIRC1 problem
Yes. It actually quit working while I was filming. Unit is 1 year old and has worked flawlessly until yesterday. Contacted Sony and it's $135 plus postage to ship to them for diagnostic and then whatever the charge to repair. Looked up when I purchased the unit and it was 6/20/2012. Bought through B&H so I probably had the unit in hand 3 or 4 days after purchase date. Wonder if they will honor the 1 year parts warranty (if parts are needed)?
Old June 20th, 2013, 08:23 PM   #4
Re: MIRC1 problem
You're *sure* CAMLINK is activated? You see the icon? There's no way you hit the hard button (it's not a menu command or button) by accident? pp 4,5.
Old June 21st, 2013, 12:01 AM   #5
Re: MIRC1 problem
Bingo, that was it. Don't know how I missed that, never have used that function. Adam, you saved me $135 and the embarrassment of a tech telling me operator error, thanks. Your tag at the end of your posts kinda' says it all.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
