Cut Z5 with Z1? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old May 6th, 2013, 09:20 PM   #1
Cut Z5 with Z1?
they have different chips, no? this is a 2 camera shoot of a dance performance and they need to match or at least be very close. anyone ever cut them together?
charlie
Charlie Steiner is offline   Reply With Quote
Old May 6th, 2013, 09:50 PM   #2
Re: Cut Z5 with Z1?
used to cut between them many years ago without problem - just check wb / gain and other basics between them.
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old May 7th, 2013, 12:59 AM   #3
Re: Cut Z5 with Z1?
The Z1 will be noticeably softer, so use that for your close-ups and leave the Z5 for the wider shots.
Old May 7th, 2013, 09:48 AM   #4
Re: Cut Z5 with Z1?
many thanks
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
