sony z5u recording to solid state disk at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old December 21st, 2012, 11:35 PM   #1
can my z5u record to a ssd? If so how.
Melvin Baggs is offline   Reply With Quote
Old December 22nd, 2012, 12:20 AM   #2
Re: sony z5u recording to solid state disk
sure - check out any number of devices - atmos ninja comes to mind, etc., but what's wrong with sony's mcrk1 cf recorder?
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old December 22nd, 2012, 12:54 AM   #3
nothing is wrong with the unit in fact I own one. just thinking can the HDMI out port be used to capture the signal onto a ssd? if it can a high capacity more stable ssd might be the way to go vs the 64gb that are starting to stack up
Old December 22nd, 2012, 01:36 AM   #4
i gather, though i've no experience, that the atmos will record mov and dnxhd. there's also a black magic unit that'll record bm's codecs.
at one stage i had similar thoughts, but reckoned that the sony cf recorder was easy, convenient and much less of a hassle than hanging some proprietary gizmo off / on the camera....
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
