60i not showing as 60fps?
Hi,
I have a Sony z5u with the memory recording unit set up as: Rec Format: HDV 1080i HDV PROGRE.: Interlace, ScanType: 60 When I record a short clip, I used MediaInfo to look at the file and got: Why is the Frame Rate at 29.970?? Start time : UTC 2012-06-13 11:33:18 End time : UTC 2012-06-13 11:33:28 Overall bit rate : 26.1 Mbps Maximum Overall bit rate : 33.0 Mbps Encoded date : UTC 2012-06-13 11:33:18 Video ID : 2064 (0x810) Menu ID : 100 (0x64) Format : MPEG Video Format_Commercial_IfAny : HDV 1080i Format version : Version 2 Format profile : Main@High 1440 Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=15 Codec ID : 2 Duration : 10s 244ms Bit rate : 24.5 Mbps Maximum bit rate : 25.0 Mbps Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.525 Stream size : 29.9 MiB (90%) Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2068 (0x814) Menu ID : 100 (0x64) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Codec ID : 3 Duration : 10s 584ms Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Delay relative to video : -245ms Stream size : 496 KiB (1%) I also brought the file into Sony Vegas, did a match properties on it and got the HDV 1080-60i(144x1090, 29.970) template. Frame rate set as 29.970 (of course I can change this) In CS5.5 AE, it says 1440x1080 (1.33),Separating(Upper) 29.97 fps Should I just ignore and overwrite the 29.970 to 60? Thanks |
Re: 60i not showing as 60fps?
It is 29.97 frames per second, not 60... It has 60 (well 59.94) FIELDS per second, and 2 fields make up one FRAME. This is because it's interlaced video.
Thanks for your help.
60p is usually related to footage shot with 1280x720@60p..
