What Format Should My Captured Video Be? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old October 7th, 2010, 10:30 AM   #1
Im using Abobe Premiere and trying to capture the best quality from my FX1000 to author a BR Disc.
After i get the video captured in Premiere it shows that my video is compressed, is that the way it should be?
It shows that it is 1440x1080/60i(1.3333) 29.97.
I thought that the video needed to be uncompressed to have the best source file.
The reason im wondering this is because i burned a blu-ray disc last night of a video that was 55 minutes and the size was only 11.0 GB.
Tim Rogers is offline   Reply With Quote
Old October 7th, 2010, 11:56 AM   #2
HDV is by nature extremely highly compressed. The video characteristics displayed (1440x1080/60i(1.3333) 29.97) are the definition of the HDV format.
But no worries. It's more than enough to make brilliant Blu-Rays.
If you are doing a lot of color correction and other post production work, you might want to look at Cineform, which sort of "de-compresses" the video so you can run it through many re-encoding passes without losing too much quality. But for simple editing and effects it's fine to edit your HDV footage natively and you will still come up with brilliant discs.
Old October 7th, 2010, 12:00 PM   #3
That's HDV, yep.
Hi there, Tim. The HDV video format used by the Z5 is highly-compressed MPEG-2, so that's what you get when you capture from the camera. About 12Gb/hour is what to expect. Unfortunately, while 1440x1080 and MPEG-2 are both natively supported by Blu-ray Disc, they are not supported together, which means that some amount of transcoding will always be required in order to put your footage on a proper Blu-ray. Depending one how much tweaking you plan to do in between capture and disc creation, you may wish to transcode to some lossless intermediate format after capture. If, however, your plan is simply to cut, add transitions, the odd title, etc., and then send straight to the disc, with Premiere/Encore, I suspect that would just be extra time spent for no gain in quality.
Best,
Aaron
Software Engineer, Video Hobbyist -- Sony FDR-AX100, HDR-CX12, Miller DS10/Solo, Premiere CS5.5, DYMO DiscPainter, 2010 Mac Pro 3.33GHz 6c
Aaron Holmes is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
