Smooth Slow Recording crashes Adobe CS5 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old May 30th, 2010, 11:42 PM   #1
Been banging my head against the wall with frequent crashes of Adobe CS5. The problem seems limited to clips made with my Z5U in Smooth Slow Recording mode. Problem easy to reproduce in both Premiere Pro and After Effects.
Anyone even using Smooth Slow Recording?
Bill Ackerman is offline   Reply With Quote
Old June 13th, 2010, 11:07 AM   #2
Yes,
I use Canopus Edius 5.5, never had a problem!
Dirk PEL
Dirk Pel is offline   Reply With Quote
Old June 13th, 2010, 05:18 PM   #3
no problem here in vegas either....
Leslie Wand is offline   Reply With Quote
Old June 15th, 2010, 04:33 PM   #4
Hmm odd, I have used smooth slow mo footage in After Effects CS5 with no issues. Also no issue when using it in Vegas either.
Jonathan Palfrey is offline   Reply With Quote
Old June 16th, 2010, 03:18 PM   #5
I use it all the time. I run edius 5.0 and Vegas with no problems.
I left Adobe 2.5 years ago for various petty reasons, have never regreeted it!!!
Curiously, are you working the native files or using an intermediary like cineform??
dale
DATS ALL FOLKS
Dale W. Guthormsen
Old June 16th, 2010, 04:55 PM   #6
dale
Dale,
Native files. I copy the M2T files directly from the CF card on my hard disk and then import them directly into CS5. I probably should say I am using a (gasp) Mac.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
