Output to 2 monitors with Z5 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old March 7th, 2010, 01:25 PM   #1
I want connect an external monitor via HDMI cables and at the same time to connect another monitor via the AV cable. Is this possible with the Z5? because I can't manage to do it. It's either one or the other but not both.
Stelios
My Blog: http://steliosc.blogspot.com
"I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis
Stelios Christofides is offline   Reply With Quote
Old March 7th, 2010, 01:48 PM   #2
I haven't tried this with my Z5s yet, but based on other Sonys I've had, they usually only output to the highest res output connected at any one time. I believe FW is not in this loop, however.
EDIT: Page 61 of the Z5E manual sort-of explains this.
Old March 7th, 2010, 03:42 PM   #3
Thanks Adam for pointing some pages for me but it didn't help me. You see I got this job to do next week and it requires me to provide a video output to a projector so the audience sitting far away can see on a big screen what I am taping ( a school musical show) but at the same time I want to use my external HD monitor that is connected via an HDMI cable. How can I achieve this?
Stelios
Old March 7th, 2010, 03:49 PM   #4
My reading of the manual -- and my experience with similar models -- is that you can't feed two sources from the cam at once, unless one of them is FW.
Perhaps some way to loop from Ext monitor out to Proj? Maybe FW out to PC to Proj?
Old March 8th, 2010, 04:43 AM   #5
Yes that might be an idea, or perhaps get a video splitter. Maybe an HDMI splitter (one for the HD monitor and then the other output to the projector). But wait...I would also need then a converter from HDMI to component AV for the projector? Complicated...
Stelios
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
