FX1000 and additional lighting... - Page 4 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old July 7th, 2009, 10:56 AM   #46
Originally Posted by Garry Moore View Post
I dont feel bad about the Sony 10/20w for the money....
You can get by with the light in a 4:3 environment. In widescreen, it just doesn't cut it for me. If it works for you, then it's a bargain. For me, I would rather spend the extra money and have a more professional product that enhances my productions. Someone else might want to spend the extra money and get a Zylight or other high dollar items on the market.
If something works for you and your customers are happy with the quality of your finished product, that's all that matters. I'm not selling the product, I'm just throwing it out there for anyone who is interested.
Rob Morse is offline   Reply With Quote
Old July 7th, 2009, 11:02 AM   #47
Actually the Comer 900 light is a cheaper alternative. It's smaller and lighter. the light output is also significantly better than the Canon VL-10, LP Micro, and SWIT/Varisoom light too.
You can check out these clips
YouTube - 6 On-Camera Video Lights Shootout - Test #2 Medium Size Room
YouTube - Comer CM-LBPS900 LED Light
LA Color Pros Blog
Old July 7th, 2009, 01:30 PM   #48
Well Taky, I'm looking forward to receiving my Comer 900.
To all, I switched to the 900 strictly for weight reasons, but am confident the light will work fine even if not as strong as the 1800.
Thanks for the excellent customer service Taky, you're the best!
Old July 7th, 2009, 02:18 PM   #49
Jeff, Do you think that you will see a big difference between the Sony 10/20 (800 lux, $90) and the Comer 900 (900 lux,$280)?
Stelios
My Blog: http://steliosc.blogspot.com
"I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis
Stelios Christofides is offline   Reply With Quote
Old July 7th, 2009, 02:23 PM   #50
I do. I'll actually set up the light next to the sony and take photographs with my Canon 40d and we'll see exactly. I could be wrong, but I expect much better results with the Comer based on Taky's videos.
I'll keep you posted.
Old July 7th, 2009, 03:31 PM   #51
If what Taky said is true, the 900 should be better than my Swit and the Swit is certainly better than the Sony 10/20.
Stelios, you can't keep comparing the lux of the 10/20 to the other lights. It's not comparing apples to apples. I can duct tape a flashlight to the top of my camera and that would probably put out more watts and be cheaper as well.
Old July 7th, 2009, 03:34 PM   #52
I used to have the SWIT light. So I compared it side by side with the Canon VL3, VL10, LP Micro, Comer 900 and Comer 1800.
Comer 900 is brighter and wider spread than SWIT. You can watch this video
YouTube - 6 On-Camera Video Lights Shootout - Test #1 Small Room
LA Color Pros Blog
Old July 7th, 2009, 04:27 PM   #53
Yes, the video is pretty thorough.
Old July 8th, 2009, 01:31 PM   #54
Rob the only measure that you have when comparing video lights, surely is the lux measurement (luminous emittance) and what I am trying to say is that, if I want more luminance in my subjects than the Sony 10/20 (800lux), then a light with 900 lux costing 3 times a much, is it really worth it? I don't think that 100lux is going to make that difference.
Ofcourse I might be wrong.
Jeff when you get the Comer 900 please do a comparison with your Sony 10/20 ( I presume you have one) and post the results.
Stelios
Old July 8th, 2009, 02:06 PM   #55
Originally Posted by Stelios Christofides View Post
... if I want more luminance in my subjects than the Sony 10/20 (800lux), then a light with 900 lux costing 3 times a much, is it really worth it? I don't think that 100lux is going to make that difference.
...Stelios
Are we talking about this Sony HVL-20DW2 light
http://www.amazon.com/Sony-HVL-20DW2.../ref=pd_cp_p_1
In the page, it said the light is 40 lux and 80 lux ONLY. Not 400 lux and 800 lux. It doesn't say the measuring distance too.
So for the Sony light at the strongest dual light mode assumed at 1 meter, the difference is 80 lux for Sony and 900 lux compared to the Comer 900 light.
LA Color Pros Blog
Old July 8th, 2009, 02:26 PM   #56
I look at the spread also, and the Sony has none.
The Comer has a wider dispersion and other features, the Sony offers nothing except a narrow beam of light.
Old July 8th, 2009, 06:44 PM   #57
Stelios
Stelios, as an example, you can have 800 lux which is concentrated as a spot, like the Sony. The other light has 900 lux which is spread out across the entire area, giving you more better overall coverage. If you took a light meter and went off center of the Sony light, the lux would drop drastically. If the Sony does have 800 lux (which that doesn't seem right) it would only be in the center. I'm going to see if I can dig out my light meter and I'll get back to you.
Old July 8th, 2009, 07:17 PM   #58
... If the Sony does have 800 lux (which that doesn't seem right) it would only be in the center. .
nah... he misread the info. The sony has 40 lux and 80 lux only. not 800 lux. It also doesn't say 80 lux measured at what distance. Comer spec says it was 900 lux at 1 meter.
LA Color Pros Blog
Old July 8th, 2009, 07:50 PM   #59
Testing is at 5 feet in complete darkness. The Sony (turned sideways for maximum coverage and no diffuser) at its brightest spot is 110 lux. Move a foot from side to side and it drops to approx 65 lux. The Swit was 76 lux (using the diffuser) at its brightest spot and dropped to 58 lux moving it a foot side to side. The Comer was 290 lux (without any filter) and dropped to 258 at 1 foot. Here is the kicker, the Comer still had 167 lux at 3 feet from its brightest spot. With the filter it dropped to about 198 lux and was about 168 lux at a foot and 112 lux at 3 feet. Also, the Sony did not fill in the picture on my LCD. The lighting on the sides was unacceptable. I didn't even bother testing 3 feet away from the brightest point. I did this with my camera, tripod, lights and Greenlee Digital Light Meter. Hope this helps.
Taky, at 1 meter I got 835 Lux.
Old July 8th, 2009, 07:52 PM   #60
Just to keep everything as accurate as possible, I would give a +/- of 9 lux.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
