#16 |
Ken, that is remarkable. I was looking at a kit, of course. $1299, not bad. Very nice sounding camera.
#17 |
Jeff, on the HV30 framegrab posted, is the focus a little off or is that as good as it gets for the camera. Based on those framegrabs alone, the FX1000 image appears to be superior to the other two's.
Wacharapong |
#18 |
Indeed, normally, the HV30 delivers a sharper image (see screengrab below). The biggest difference between the HV30 and the Z5 (or Z7, for that matter) is the washing out of bright objects, like the white shirt here. The dynamic range is not near as good as in the more expensive 3-chip camera's.
#19 |
camcorderinfo's review of the fx1000 claims that it destroys the XHA1 in sharpness.. which probably means it destroys the hv20/30 and hmc. It states "approximately 900 lw/ph and a vertical resolution of 800 lw/ph".
Do you find this to be true? Also, camcorderinfo states that it;s low light is worse than the xha1, however, many people have claimed that it's low light is in fact better than the HMC.. do you find this to be true? thanks! |
#20 |
The trouble having avchd as the second cam is the footage has to be converted, to my mind shots can not be compared unless they are from the same distance and angle to the subjects.
#21 | |
#22 |
Ken, how does the recording unit work for your Z5? I'm thinking of adding one onto to my FX1000.
By how does it work I'm asking literally how does it work? Are there cards involved or is is all self-contained? What kind of files do you get when capturing SD? |
#23 |
Jeff, the unit works well but does have a somewhat annoying 'lag' that you need to get used to. In other words (at least in the Z5 configuration), you hit 'record' on the camera and the card recording doesn't begin for about two seconds. So you need to anticipate your shots or simply keep it rolling.
I've found that faster cards reduce the lag time, but it's still there. The card simply inserts into the reader once you open the door of the unit. Keep in mind the reader does reduce battery life (by nearly 20% or thereabouts). Although light, it does add a noticeable weight when attached to the rear of the Z5. To be honest, I haven't shot with the unit in SD, but I believe the files are standard .avi. |
#24 |
Thanks Ken. Are the cards expensive?
#25 |
Jeff, no, they actually use pretty standard CF cards. You just need a high enough write speed.
Here's a typical example: SanDisk | 4GB Extreme III CompactFlash Card | SDCFX3-004G-A31 |
#26 |
Thanks Ken.
#27 | |
From the brochure: "SYNCHRO mode "When using camcorders that support external rec control, such as the HVR-Z5U, HVR-V1U, HVR-Z1U, DSR-450WS, DSR-400 and DSR-250, recording to the HVR-MRC1 or HVR-DR60 is directly controlled by the press of the camcorder’s rec start button.*3 *3 In this mode, a rec start delay of approximately 0.5 seconds may occur after the camcorder rec start button is pressed. "FOLLOW mode "When using camcorders that do not support external rec control, such as the HVR-A1U and DSR-PD170, the FOLLOW mode can be used to start and stop recording by the HVR-MRC1 or HVR-DR60. In this mode, the HVR-MRC1 or HVR-DR60 periodically checks whether the camcorder is in rec mode or not, and follows this status.*4 *4 In this mode, a rec start delay of up to 2 seconds may occur after the camcorder rec start button is pressed." My understanding is that the FX series supports neither mode, but I could, of course, be wrong. http://ws.sel.sony.com/PIPWebService...re_Final08.pdf |
#28 |
Thanks Adam, very important info you shared...
The files on the card are fat 32 and limited to 4gb each, right? A friend of mine has two Hard disc drive recording units for sale (40GB each) and those sound like another good way to go to achieve a tapeless workflow. Upgrade those babies with 120GB HDs and it would be sweet. What has happened is I have gotten a taste of the tapeless workflow thingy with my new HMC150, but am not at all in love with AVCHD. You need to rejoin the files, then transcode them, blah blah blah. It is an unlovely workflow. And yes I know about Cineform, but my first time with it on these AVCHD files the audio was a different length than the video. On the other hand, I shoot primarily SD widescreen, and the Panasonic doesn't. The AVCHD puts a kink in my workflow. I dislike it enough that after a few nights of playing with these freakin files I am close to selling the camera less than a week after buying it, pro audio connections be damned. The footage looks good, but not THAT good. I used the Panasonic as a back up cam for a half hour ceremony this evening and I'm not even going to bother to get the files off of the card. |
#29 |
Jeff I am not going to sound cynical or something but my advise is to sell both the FX1000 and the Panasonic (even if you loose some money) and get the Z5. I, (like you) soot SD widescreen at the moment and the combination of the Z5 and the MRC1 is just awesome!!!
Stelios
My Blog: http://steliosc.blogspot.com "I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis |
#30 |
Stelios, you are just determined to get me to buy a Z5, aren't you?
Well, you might be getting close! I'm going to be putting the Panasonic up for sale, and I might take your advice and do exactly what you say. |
