Matching the FX1000 with Panasonic HMC 150 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old May 19th, 2009, 11:43 PM   #1
I'm looking at a used HMC 150. It's being sold cheaply and I just hate to pass it up.
Anyway, if you've used this camera alongside the FX1000/Z5 I'm interested to know how footage from the two work together. My primary application for the cam will be weddings.
Old May 20th, 2009, 09:46 AM   #2
You might try posting that same question in the panny forum Jeff.
Tim
Tim Akin is offline   Reply With Quote
Old May 20th, 2009, 10:08 AM   #3
Thanks Tim, you're suggestion is spot on, of course. I was trying to avoid double posting....but if I don't hear something soon I might have to reach out in the Panny forum.
Old May 20th, 2009, 02:47 PM   #4
Hi Jeff,
I made a post on the Panny board about matching an HMC150 to a Z5. Here is the link.
http://www.dvinfo.net/conf/panasonic...c150-sony.html
While I have not shot a wedding with the FX1000 and an HMC150 I have shot a wedding with a Z1, FX1 and HMC150. The HMC150 was going to be a a fourth unmanned camera, but my second Z1 went down,
So here is the run down.
HMC150 became my primary camera (front cam for ceremony and primary cam for reception). I used the FX1 for prep and fisheye shots at reception. Z1 for girls prep, back camera and secondary at reception.
At that time I did not have the info on matching a Panny to a Sony. I don't think they mismatched too badly and then if you used the suggestions at the link, they would probably look even better.
Here is the highlight from that wedding. Allow a few seconds to load.
Gainseville Wedding | Highlight Preview | Von Wedding Films.com
Mark Von Lanken
www.VonWeddingFilms.com
Mark Von Lanken is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
