Save setting to memory stick at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old March 3rd, 2009, 05:02 PM   #1
I can't find this anywhere in the FX1000 manual, but there has to be a way to save the cam profile to the memory stick and then load that profile to another 1000.
Tim
Tim Akin is offline   Reply With Quote
Old March 3rd, 2009, 07:55 PM   #2
Not sure if it's the same but on the Z5 it's the very bottom of the menu-Camera Prof.
That's where you save and load as well.
Rob Morse is offline   Reply With Quote
Old March 3rd, 2009, 09:19 PM   #3
That's were I thought it should be.....but it's not. I guess that's something else they left off the 1000.
Tim
Old March 4th, 2009, 12:12 AM   #4
It's not something they *left off* the FX1000... it's something they *added* to the Z5.
Half empty/half full....
Old March 4th, 2009, 07:18 AM   #5
I guess your right Adam, if you own a 1000 'they left it off'....if you own a Z5 'they added it on'. :-)
Tim
Old March 4th, 2009, 01:25 PM   #6
To-MAY-to, to-MAH-to...
Adam Gold is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
