20X lens a bluff?
Well it seems one is always learing new things in this video game.
Tom Hardwick could be spot on when he says there is little difference in the focal length (when zoomed right in) between the Z1 and FX1000/Z5. I just did a comparision with the naked eye between my Sony TRV900 (12X) and the FX1000 (20X) and well there is virtually zip difference. I will pop a test onto my computer and see what the result is but I am really amazed at this & honestly a bit disappointed. As I film alot of sport I am going to need to source a 72mm 1.4/1.5 tele I would think. If not use the 30 digital extender feature although previous cameras that I have used digi zoom on have had mixedresults. Some days the footage looked fine and then other days not so good. |
#2 | |
Of curiousity I looked up the specs for this two camcorders and here is what I found: Focal distance (35mm equivalent): TRV 900 - 41.3 - 496mm FX-1000 - 29.5 - 590mm As you'll see, the FX-1000 has a much more wide-end than the TRV 900.
- Per Johan |
Did a comparison with my xh-a1 which also has 20x zoom and mine was able to zoom in further then the fx1000, not that much but there was a difference. As Per said the fx1000 also has a wider angle lens then the xh-a1 which could explain why it doesn't zoom in the same amount as the xha1
The FX1000 has a remarkably wider lens than previous Sony's. I think the FX7 starts at 39mm and goes out to 780mm. The FX1000's angle of view is equivelant to a FX7 with a 0.75 WA adapter mounted.
#5 |
As everyone above have said, its just due to the fact that the Z5's lens starts a lot "further away" due to the lens being so wide on its maximum.
But this is a great thing about this camera, as i have found it improves its versatility especially when filming indoors! The only other thing to note is that with the 20x zoom lens, you will (like a lot of high zoom lenses) loose several stops of light and end up with an intial F1.6 going down to F3.4, but it is as i understand it an inherant side effect of all zoom lenses. Edit - Just as shaun says the more expensive one's can keep their F setting all the way though the zoom, e.g. the ex1 lens, it is only 14x zoom i believe but doesn't loose any light at all!
Stake Productions - Director, Editor, Cinematographer, ...Sony HVR Z5E Last edited by Daniel McPake; February 14th, 2009 at 05:29 PM. Reason: Like he said! |
#6 |
This 20x zoom thing, the lens ramping issue particularly, was the subject of my previous rants on the camera. The lens starts from a much wider position as has been stated. So the 20x is not a bluff, it is 20x.
But if you're coming from as 2100 or PD series cam it is a huge change. I personally love the wider starting point with the cam, it is fantastic. On the other hand, in my work I find the lens ramping a huge issue for attempting to get a closeup during wedding ceremony when upfront. Because I'm starting wider, by the time I get zoomed in for an extreme closeup the exposure has gone to 3.4, and I cannot use it. I have to stop zooming at a point that is well before I want to be. Unfortunately for me, I had no understanding of the lens technology behind the camera, or of the necessity for the lens ramping with this type of camera and I was very upset at this aspect of the camera. As has been said before it is not a defect, but it is what you get with a 20x zoom on an inexpensive cam. Other than this the FX1000 is a fine camera and I do like it very much. |
#7 |
Jeff, when you say you can't use it, is that because there is not enough light?
Tim |
#8 |
Not necessarily ALL zoom lenses, but certainly the more budget oriented ones.
Shaun C. Roemich Road Dog Media - Vancouver, BC - Videographer - Webcaster www.roaddogmedia.ca Blog: http://roaddogmedia.wordpress.com/ |
#9 |
No Tim, I can't use it because the iris has closed up to 3.4 and the image is underexposed.
#10 | |
Personally, I find it's much better to lose a bit on the telephoto side and gain it at the wide angle side. I think Sony did a fabulous job with this lens. It's so much better than any Sony cam lens I've had before. For me I'd much rather start with a nice wide image that really takes advantage of the 16:9 aspect ratio than get in a bit closer. Compare the wide angle image with your TRV900 and I think you'll be shocked at how much more image you really get!! |
#11 |
But Jeff, if there's enough light, the cam should be adjusting the image so that your exposure remains consistent (assuming you're not in a totally manual, fixed setting setup). I can see if the light is insufficient you'll get a darkening of the image since the camera can't compensate short of really ramping up the gain if you let it.
#12 |
30X extender
Ken, yeah no doubt having a real wide shot will be cool. Whilst I like to get in tight alot of my sports filming is also "wide" as the football play is often in front of me and players and coaches want to see where everyone is standing. Having the ability to be really wide is going to be great.
I well may just hit the 30X extender for those crucial moments when the play is well away from me. Its pretty cool how you can assign a button hit it and bang the camera is 30X. My Aussie Rules season starts up soon so I am looking forward to testing this out. Alot of what I do is not going broadcast so a bit of digi zoom distortion here and there may be acceptable. Sometimes its better to capture the moment even if everything is not in the perfect world for us producers. Hate to say it but the person watching at home will not even know the difference but will be a bit more excited seeing the play and "feeling it" as I cam zoomed in more. Guys Aussie Rules is the most brilliiant game to film. I have filmed cars, bikes, people running, dancing concerts, weddings and "footy" for me is just brilliant! Jeff on the lens ramping issue maybe just pop the camera into auto and see if you get some OK results that way. Then you are just concentrating on getting a good frame (that's of course if auto iris is doing the desired job). Hoping that may work but I can see your frustration when you have to change the way you film because a new camera doesn't do what the old one did. A bit like me and my rec/pause/rec rant a few weeks back. I think we all just need to accept that cameras in this range will never have everything we really need. |
#13 |
Martin / Jeff,
The FX1000/Z5U has gobs of resolution, can you just "zoom in" in post? I've done that before and have not seen any meaningful deterioration in quality. Seems that may give better quality than using the digital zoom, though it may depend on the extent to which you need to zoom in beyond the optical 20X. |
#14 |
Not a bad idea Steve.
Overall, the f-drop (lens ramping) is just an undesirable side effect of having an consumer cam and there really isn't much to do but work around it. |
#15 |
editing
[QUOTE=Steve Wolla;1012296]Martin / Jeff,
The FX1000/Z5U has gobs of resolution, can you just "zoom in" in post? Steve thanks but the nature of what I will be doing is film and record "live" to DVD. Sometimes I am filming from a standing height of 6 feet and my subject can be 80 metres away! I simply need to be able to get in there. Thinking the Canon 1.4 that Tom uses maybe the go for me. Trying to spend as little time in front of the computer so please don't suggest anymore post editing - ha ha but true !!!!!!!!!!!!!! |
