Export settings for Exporting from CS4 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old February 10th, 2009, 11:54 AM   #1
Hi folks
I've just made my first HDV movie with my Z5. Can anyone tell me which settings would be good for exporting the movie for Vimeo or Youtube? My fist attempt produced a 950mb file for the 4 minute movie!
I will show of course show my level of camera skill (first shoot with the Z5, first editing with CS4) after I get the movie uploaded...
Thanks Billy
Billy Ellwood is on Vimeo. Film club www.newcastleaca.co.uk
i7 7700k, Asus z270f, 32gb ram, Windows 10, Premiere CS6.
William Ellwood is offline   Reply With Quote
Old February 10th, 2009, 12:56 PM   #2
For YouTube I do not know, but for Vimeo:
H.264 codec, 24 fps, Data Rate 5000 kbits/sec, 1280x720 pixels, De-interlaced, Audio 44,100 kHz, 128 kbps.
Which can be found easily on Vimeo itself . . .
Jo Ouwejan is offline   Reply With Quote
Old February 10th, 2009, 05:36 PM   #3
Thank you Jo.
I take it this is good for Pal. I'll have a play next time I am at the edit rig.
Old February 11th, 2009, 02:05 AM   #4
Originally Posted by William Ellwood View Post
Thank you Jo.
Oops! I took you for someone from the US and that is why I specified 24 fps. And of course that should be 25 fps for PAL . . .
Old March 24th, 2009, 05:16 AM   #5
Well here is my first Vimeo HD export from Premiere CS4. It is at 5mbs, 1280x720, audio at 48k I think, and in PAL 25fps. It might be deinterlaced.
I didn't do the camera on this one.
Your Note Said It All on Vimeo
Old March 24th, 2009, 08:51 AM   #6
So you've lost some of your hair over the years, have you not?
Or is this the wrong remark at the proper time?
I got so confused . . .
Old March 24th, 2009, 12:29 PM   #7
Nicely done!
What video bit-rate did you use on export?
Bill Ackerman is offline   Reply With Quote
Old March 24th, 2009, 12:46 PM   #8
great video........as it was your first video......did you film it in manual mode or auto?
Resham Singh is offline   Reply With Quote
Old March 24th, 2009, 05:40 PM   #9
Thanks for the comments guys.
The settings on Premiere CS4 were: (and these are on the export settings box)
Note - I don't know how good these are or if they can be tuned better.
Format H.264
PAL 1280x720 pixels
25 FPS
Field order - none - Progressive
Pixel aspect ratio - square pixels
Profile - main
Level 3.1
Bitrate settings:
Bitrate encoding - VBR 1 pass
Target bitrate 5Mbps
Maximum bitrate 8Mbps
Audio AAC
Codec AAC
Stereo 48kHz
Audio quality - high
Bitrate 128kbps
Precedence - bitrate
Resham - the cam would have been in manual mode for everything.
Old March 25th, 2009, 01:56 AM   #10
I don't get it, Billy. Per the Vimeo FAQ, I use almost the same settings except for 24fps and level 4.1, but even if I change to exactly the same as you I get much, much bigger files. For example, I have a movie a little over a minute long that is probably a little more static than yours (hence more compressible). At your settings, it is over 40MB. The only way I seem to be able to cut it down to 5MB is to lower the bitrate to .5MBps. ?????
Old March 25th, 2009, 02:02 AM   #11
My 5 minute movie is 188mb Bill. I think the 5Mbps is the speed of data transfer, not the total filesize.
Cheers
Old March 25th, 2009, 06:17 AM   #12
Cheers
My mistake. Thanks.
Old April 22nd, 2009, 01:56 PM   #13
Does anyone know if these are the same settings for a 'plus' member (ie. paid up members get higher video quality).
Chris
Christopher Warwick is offline   Reply With Quote
Old April 22nd, 2009, 03:38 PM   #14
The answer I think is yes - I doubt you get superior encoding extras just because you're a plus member, not in HD anyway. I've not looked at the fine print mind! I know you can upload as many hi def files you like etc... not just one a week.
I use HDV. I've set the audio freq to 44k to minimise any lip sync possibilities.
I'd like to see a guide for a little embellishement of the settings I've got to export to Vimeo from CS4.
Like Video, profile - baseline, main or high?
Like Video, level - 1 up to 5.1. Which is the best?
Like bitrate settings - CBR, VBR 1 or 2 pass?
Like target bitrate and max bitrate?
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
