Sony Z5 presets at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old January 25th, 2009, 04:13 PM   #1
Sony Z5 presets
Hi guys,
Is it possible to save and load presets with Sony z5?
Is it possible to set image parameters or load them from memory card like you can do in other cameras like XH-A1?
I've seen there are a lot of image presets for Canon XH-A1 so you can set the XH-A1 to look like Panasonic or to have a film look?
If it's possible it would be interesting because Z5 has some good points respect to XH-A1 (wider lens, low light sensivity and bigger zoom).
Please answer me.
Thank you very much
Bye
Ernesto Del Gesso is offline   Reply With Quote
Old January 25th, 2009, 06:40 PM   #2
The Z5 and the FX1000 use a memory stick pro duo for saving various camera profiles. Those profiles can be reloaded later to match camera settings from a previous shoot, for example.
Greg Laves is offline   Reply With Quote
Old January 25th, 2009, 06:49 PM   #3
Thanks Greg,
this is a good new!
thanks a lot
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
