#271 | |
#272 |
So Martyn, what's happening to the SR12's footage in post that it starts out sharper than your FX7 and winds up softer?
#273 | ||
And the problem with trying to see detail in the shadows is a) they're not lit for a reason, so you really *don't* want to see this, and b) if you try, you just get a ton of grain as the cam struggles to bring up details. I was actually concerned about losing details in darker, but still lit, areas of the stage, but the cam seems to know what to do. Using Black Compress last night got me exactly what I wanted. But I will try bringing the knee down to 85% (low). Or, since the cam always seems to be smarter than I am, just leaving it on AUTO. Much more experimenting still to do. |
#274 |
Adam, so how was the overall quality and how did it compare with the other cams you used?
#275 |
I never run in auto because this destroys the lighting effects of the lighting designer apart from relying on the camera to set gain( grain). I watch zebras and make sure that faces or light yellow costumes are correctly exposed. This is the most one can get out of most cameras. Most of the time my FX1 is at 9db, and around F3.4 to F4 for theatre shows. Gives good depth of field for the stage and grain is manageable at 9db. Spotlight mode manages gain and iris in an attempt to stop saturation of bright scenes it doesn't always work and will go up and down with the lights. Just like any auto systems when the stage blacks out it will try and correct when the lights then come up bright it will have to shut down quick. This pumping is noticable and just isn't there in full manual mode.
As far as detail in the shadows is concerned I am sure the costume designers want you to see that the suit is pin stripped or that there is a pattern on the black dress. IF the stage lighting designer doesn't want anyone to see the corner of the stage it will not have any light and will not be seen by anyone. Peoples eyes are far more sensitive than a camera and the audience will see far more of the stage than any recording. Ron Evans |
#276 | |
Ron -- I get everything you're saying and can't quarrel with any of it. It just hasn't worked that way for me, that's all. I never have a problem using AUTO/SPOTLIGHT, but that's just me. It does try to compensate when the stage blacks out but eventually it gives up. And I do the fade in post anyway. Appreciate all the input. |
#277 |
Adam, if you have access to a large screen 1080p HDTV, THAT would be the way to judge. I think on most of these computer monitors, all these cams look pretty much alike. The monitors hide so much of the goodness these cams have to offer.
#278 |
That's an excellent point. I need to get an AV receiver or other form of mixer with front inputs as I'm all out of inputs on my 65" Sony RP. And they're all in the back anyway.
#279 |
Using a TV monitor in editing
I think its a good rule of thumb to be editing with a TV monitor also displaying the "real" picture as you are doing the edit.
Just firewire out and sit it along side your computer monitors. A great reference to how things really look. Things are on the improve for me and the FX1000. The digital extender I can confirm is a great feature for sports events. Its maybe not as sharp as normal optical but certainly not as noisy as the not so long ago days of normal Digi zoom. Anyone filming horse racing, or gold or anyhting really where you need to get a closer look will be happy. I am not sure about for wedding where you may like to track a wedding party from say 50m away. It would be an interesting test for some to do and see if they like the result. Certainly you can pick up better facial expressions being closer in so well may be an alternative to putting a tele lens on/off. |
#280 |
#281 |
I agree; I actually have two -- one connected to the deck so I can monitor during capture, and the other attached to the video card for full-screen playback from the timeline.
#282 |
Sorry, i dont have time to read the whole topic, just a quick question:
FX1000 LCD screen show the picture in overscan format or show the full 1080 lines frame? if not, how can you compose a shot, if you dont know what the viewer will see on a full hd lcd tv that is underscan? |
#283 |
Very good question Prech, and I await the replies with interest. I hate the huge overscan on my Z1, and the underscan mode reduces the image size on the screen so much that it's quite unacceptable.
#284 |
I was always under the impression that overscan & underscan were more a function of CRT displays. A 1920X1080 LCD display should show the entire picture without any overscan or underscan.
#285 |
Hi Ken.
please read my post again. The question wasn't THAT! (and for example my LG 37LC51 still used the overscan mode!, and it wasnt crt..) |
