Please Post Mixers You Use For An Hvr-z1u!!!! at DVinfo.net
Old July 7th, 2007, 03:46 PM   #1
Anycast Mixer with a couple of Z1U CameraS!!!
Does anybody have any experience with a couple of Z1U cameras with a Sony ANYCAST mixer.
If so what do you think?
Joseph
Joseph Hutson is offline   Reply With Quote
Old July 7th, 2007, 03:48 PM   #2
Could everybody please post what mixer you use for the Z1U.
Our church needs to buy one next week.
We would like on that could output both HD and SD.
THANKS SO MUCH!!!!!
Joseph
Old July 7th, 2007, 04:09 PM   #3
Hi Joseph and welcome to DVinfo! Our search function is a good place to start with a question like this:
http://www.dvinfo.net/conf/showthread.php?t=49398
http://www.dvinfo.net/conf/showthread.php?t=79315
Also, please don't start more than one thread on the same topic. I've merged both of your threads together so we can keep the discussion in one place.
Old July 7th, 2007, 06:10 PM   #4
Having been a long time user of Edirol products (and I have never had a bad one) I can see no reason why the 440HD wont suit you down to the ground.
http://www.edirol.com/index.php?opti...=33&Itemid=385
It will accept and output HD and SD signals out of the box for about $12,000 US as opposed to the Anycast's $17,500 which will not deal with HD signals out of the box.
If you want the title generation the Edirol will accept input from a common PC/Laptop SXGA HD15 signal. As for recording/encoding you can either use the SD signals via a trusty canopus ADVC55/100/whatever analogue > firewire converter (my preference for SD at the moment as it records direct to DV with open source software) or any other video capture card in a regular PC or Mac. HD signals are also catered for with something like the Black Magic Intensity http://www.blackmagic-design.com/products/intensity/ or do a forum search for how others are using theirs.
Basically it comes down to this the $12k V-440HD + $5k PC/Mac gear will cost you the same as a stock Anycast, will do HD Mixing, Recording and Encoding for web where as the Anycast will only do SD.
Go buy the Edirol, you wont be disappointed.
Gregg Bond is offline   Reply
