FX-1 pass thru device.. at DVinfo.net
Old June 19th, 2007, 05:51 PM   #1
Hello,
Can I use my FX1 as an analog to firewire pass thru device? Looks like i have a situation where i may have an analog feed, but i need to capture it live using DV Rack.. Which of course needs a Firewire input.. Can this be done?? (no HD here, just DV)
Mike m.
Mike Moncrief mikemoncrief@gmail.com
www.themikemoncrief.com
Mike Moncrief is offline   Reply With Quote
Old June 19th, 2007, 07:31 PM   #2
Yeah, sure you can do this. Check the manual under the "Dubbing/Editing" section for "signal conversion function".
http://www.nosmallroles.com
Vito DeFilippo is offline   Reply
