72mm lens cap
One detail I found lacking in both the PD170 and the Z1 is their not having a protection lens cap.
Even if you keep an UV filter on it all the time, you have to keep it clean and protected from dust and finger oil smudges. The case I adapted for my Z1 fits exactly on the internal airplane baggage compartment. For that I had to cut the case foam into a practical shape. The sunshade goes into a different hole inside the case, so the filter stays close to the fabric I used. Electrostatic attracts dust to the lens, so you have to brush it away every time you take the camera out. A lens cap would be handy. There are several 72mm lens cap available, used on other lenses. From Nikon, Canon, Olympus, Tamron. Going from $13.50 to $6. But I wonder if they would all fit the Z1. Not willing to order one from here and not working, I wonder if any of you is using one. |
#2 | |
Avoid the plastic snap-on or push-on types. They fall off too easily. Get the metal screw-in types. They have the same thread as the lens and will also screw on to a filter. Good camera shops carry them. Here's one: http://www.bhphotovideo.com/c/produc...etal_Lens.html |
#3 | ||
The question is if snap-ins are universal. Quote:
Threaded accessories are not made to take in and out all the time. It tends to destroy the threads and that would be a very bad thing. |
Hi Carlos. I have two 72mm lens caps. One is a metal screw-in type, like a filter. Got it at a used camera shop, no idea who makes it.
I also have one that snaps on with push-in buttons on either side. It's just a cheap plastic one that came from a rack of generic supplies at a camera store. Don't know the brand, it only says "Made in Taiwan" on the inside. But I wonder if it wouldn't be a better idea to get a different bag or case so you can leave the original lens hood attached? That's what I do. I don't use either of those caps on my Z1. Regardless, I think any 72mm cap should fit the camera. My snap on cap only cost a few dollars, so you don't stand to lose a whole lot by trying one. |
#5 | ||||
#6 |
FWIW, my method of keeping lenscaps handy is to put a small strip of "male" velcro on the lens cap, and a small strip of "female" Velcro on the top of the cam, or in an area on the cam that is convenient. The cap attaches to the body in this manner. I don't like strings/lanyards, as they tend to bang around and make noise.
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
#7 | |
