Play JVC 720p on FX1 and capture to PC with Firewire at DVinfo.net
Old May 8th, 2007, 08:51 AM   #1
Is it possible to do this? I've searched but only found some older threads about this. I would like to rent a JVC HD100 and later on transfer the footage through firewire with my FX1E.
According to the older threads the FX1 would only output a component signal and a digital transfer through firewire is not possible. Has anything changed in the meanwhile or does the newer JVC model write different data to tape that would make it possible?
Dek Rypter is offline   Reply With Quote
Old May 8th, 2007, 12:47 PM   #2
I did a shoot recently for a short film the main cam was the
JVC GY-HD110U the cam had an audio problem so I tried loading the tape from the JVC into my Sony V1U & Z1U neither cam could read the JVC format.
Brian Rhodes is offline   Reply
