Exactly how much resolution loss in the conversion to 24p? at DVinfo.net
Old April 19th, 2007, 08:39 AM   #1
I almost had a Canon XH-A1 but now it looks like I can't get it anymore, I might have deal on an FX1 instead so I'm heavily considering that. The deal breaker for me between the two was obviously the 24p but with the fx1 I can convert with Natress. So my question is shooting in 60i and converting to 24p, just now much resolution loss will there be? How apparent is it on a larger screen? I would be using it for my first feature and I just want a difinitive percentage answer and hopefully testomony from someone who has done the same.
Evan C. King is offline   Reply With Quote
Old April 23rd, 2007, 05:19 PM   #2
I don't know the answer to that that - but I do know that the Canon A1 loses 10 - 15% of it's vertical resolution in progressive mode compared to shooting interlaced. So that's worth bearing in mind when you do find out the answer...
Kieran James is offline   Reply With Quote
Old April 23rd, 2007, 05:55 PM   #3
Images: 1
http://www.dvfilm.com/fx1/index.htm has good framegrabs demonstrating resolution loss (or lack thereof)
I find the loss is negligible with my conversion with DVFilm Maker. This is where my 60i converted to 24p footage has been blown up and projected to a 40' screen, still very sharp and watchable. I'm sure it's no less than 10%, but can't be much different.
I use a 35mm adapter on top of this and still get great, crisp footage, so it can't be that bad.
BenWinter.com
Ben Winter is offline   Reply
