French Flag Solution at DVinfo.net
Old April 17th, 2007, 05:01 PM   #1
I need to get a french flag for my FX1, but they seem very expensive considering how simple they look to make. Thoughts?
www.LegacyHDV.com
Weddings | Corporate | HMC150s | FCPX | Encore | Lion
Dana Salsbury is offline   Reply With Quote
Old April 17th, 2007, 07:20 PM   #2
I know this sounds cheesy.... but have you ever seen those gooseneck bendable things with a magnifine glass on one end and a clapt on the other?
well..... get one of those...... then get 2 8.5"X11" sheets of that black foam sheet stuff they have in the craft section of walmart or at craft stores.....
spray mount/sandwhich the sheets over the mag glass....
clamp the thing on the cam or tripod..... and voilį
cheesy I know. but for under $20 it works.
Christopher Witz is offline   Reply With Quote
Old April 17th, 2007, 09:46 PM   #3
Of course I would never admit it if I followed your advice, but thanks for sticking your neck out there!
Hey, I would have a great close up shot if I wanted to fry ants with the magnifying glass! LOL!
www.LegacyHDV.com
Old April 18th, 2007, 02:31 AM   #4
You might wanna check out http://www.geardear.com/
They are at least a bit less expensive than what I have seen on the market. You might also want to get used to the thought that a french flag is something that last a lot longer than your camera will. Buying something cheaper will probably not last as long as a high quality manufactured product.
The Russian Captain (upcoming feature) http://trc-movie.blogspot.com/
My movies http://www.larssonfilm.com/
Fredrik-Larsson is offline   Reply With Quote
Old April 18th, 2007, 06:15 AM   #5
cost almost nothing.
just glued a flash/accessory socket on the sunshade so a can slide in a folded aluminium sheet .
http://www.giroud2.com/divers/fx1a.jpg
Old April 18th, 2007, 06:35 AM   #6
hey.... what type/kind/brand of glue do you recommend?
Old April 19th, 2007, 04:02 AM   #7
Nice job Giroud !
Jeff Rhode is offline   Reply With Quote
Old April 19th, 2007, 05:38 AM   #8
in fact i used double sided tape (the thick one, like with foam, not the thin one to fix carpet).
This way i could fix a small aluminium plate (U shaped) holding the accessory socket (because the top of the sunshade is not perfectly flat) and I can remove all the stuff easily if necessary.
it is very compact because it just out of field from few milimeters.
You can also see at the bottom of the sunshade the modification that allows me to rotate the circular polarizer screwed on the lens inside the sunshade.(not looking good, but works really well)
Here i used glue for PVC (contains solvent that slightly dissolve plastic, so when it's dry it is rock solid)
(hoya makes an ultraflat one that just fit, and you can find it on ebay for less than half price).
the next step will be to cut a cokin filter holder to glue the plastic rails on the front of the sunshade, so i can slide a progressive ND filter (must be the X-Pro size 130mm x170mm).
B&H is selling a kit with filter holder and 3 filters for less than 200$.
(do a search on B&H web site with "X-PRO" as keyword and select cokin.
They got several kit, one with only ND filter, another one with blue and tobacco.
( http://www.bhphotovideo.com/bnh/cont...ughType=search)
if you want to go cheap, just buy the filter (http://www.bhphotovideo.com/bnh/cont...ughType=search)
and get a cheap filter holder from ebay (the Z format) for about 10$ (i still have to check with filter thickness, since the X-Pro serie is probably thicker than the Z-pro)
and the last step will be to add a line of white led all around the sunshade so i got a kind of ring led.
that is my Frankenstein-all-in-one sunshade.
Old April 23rd, 2007, 09:52 AM   #9
DANA
I have attched a french flag to my original sony lens hood on My Fx1 And V1u.
http://www.dvdaction.net/index_005.htm
http://www.dvinfo.net/conf/showthrea...518#post641518
Old April 23rd, 2007, 12:04 PM   #10
Thanks for the idea! I read that you used a Hama flash mount and bought the shade from eBay. I'd like to do the same, but I don't know enough about finding a shade. What key words should I use for the search, or is there a specific model I should look for?
www.LegacyHDV.com
Old April 23rd, 2007, 04:10 PM   #11
DANA
try this link the french flag will have to be cut approx. 3/8"
http://cgi.ebay.com/French-Flag-For-...QQcmdZViewItem
I can do the mode for you if you buy the parts.
Old April 25th, 2007, 09:29 PM   #12
That's very generous of you. I have access to a shop, so I would see if i could do it myself, but again, that is really generous.
It seems that you could glue the visor straight onto to the camera. I can't see the need to twist it all around with the flash mount. Thoughts? The only problem I see is the desire to take it off for stowing.
www.LegacyHDV.com
Old April 26th, 2007, 07:37 AM   #13
You glue the flash mount to the lens hood using Goop you can buy this product at Home Depot. First remove the lens hood from the cam lightly sand the area with 600 grit sand paper. Apply Goop to the area for mounting and also apply it to the bottom of the flash mount. Let it sit for approx. 3min. Then apply the flash mount to the lens hood, let it sit for approx 24hrs.The French flag is removable.
flash mount
Old April 27th, 2007, 06:22 AM   #14
gosh.... you could make a larger mattbox/flag that wraps aound the side with this solution..... maybe put a flash bracket on both top and bottom ( or sides? ) so the whole thing slides on sturdy..... I'd by one or 2 if it was sub $100!
I'm just a little hessitent to glue anything to my camera ( or shade ) as i tend to sell off my cams for the next best thing every 18 months or so...
have you seen the mattblox? looks cool... but I heard it's to flimsy.
Old April 27th, 2007, 09:50 AM   #15
It might increase the value of the cam to have it.
www.LegacyHDV.com
