Thread Tools
Search this Thread
Alternative to BeachTek boxes
I'm searching an alternative to the BeachTek Boxes. Does some clones exist?
Don't like the company? :)
You'll be hard-pressed to find similar quality adapters with equatable price tags. Beachtek's popular for a reason.
BenWinter.com |
No, just looking for cheaper solutions.
I think SignVideo builds their own adapers. Might give them a look. (SignVideo.com)
Chris J. Barcellos |
#5 |
#6 |
no, want to connect a headphone to monitor the sound.
#7 |
#8 |
Sorry, can't see what's the relation with Beachtek boxes. They are passive or active mic adapters, not headphone amps. I think they used to have a LED VU meter that could be used as headphone amp, but I don't know if it's still made. |
#9 |
I have a signvideo box for a GL1 and we also have a couple of Beachteks. The Beachtek has the controls at the rear (at least on that model) and they are less likely to get moved by accident--the Sign has them on the right side under the side grip. Also the input knobs on the Sign rotate smooth and I had to put rubber washers in between the knob and body to keep them from changing accidentally. The Beachtek has indexed knobs that "click" into position. It's the little things that make it better....but the audio quality seems similar.
#10 |
#11 |
No phantom provided by these boxes if I´m not mistaken?
Is there any sub $250 boxes that provide phantom power? At least this one seems to provide 18V phantom http://www.bhphotovideo.com/c/produc...4_Channel.html Regs, T |
#12 |
Most of the conversion boxes have models that allow/support phantom power from the box, yes. Beachtek has several, as do the Studio 1 boxes.
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
#13 |
I use a Jucedlink CX231, It's the version with 2ch and phantom power.
It has preamps so the result is better than a passive beachtek. I really like this solution, just google Juicedlink if you wanna know more. |
