FX1 Polarizer Compatibility at DVinfo.net
Old March 12th, 2007, 09:55 PM   #1
Dumb question: I have a 72mm circular polarizer I used on my Canon SLR, will that fit the 72mm mount on my FX1? Will there be any 16x9 vs 4x3 aspect issues?
Dave Knife is offline   Reply With Quote
Old March 12th, 2007, 10:16 PM   #2
Not a dumb question, and no, you won't have problems, and yes...it will fit.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old March 12th, 2007, 10:19 PM   #3
Thanks for the prompt reply, Spot. Good to hear still and vid are compatible.
fldave
Old March 13th, 2007, 07:27 AM   #4
I imagine you will be fine unless the filter has a really thick rim. I have an old 72mm Schneider linear polarizer (the kind that rotates) and when you zoom all the way out on the Z1 there is a slight bit of vignetting. But this filter has a pretty deep rim. Just to make sure this isn't happening, point the camera at a light, evenly lit surface and check the full frame image for vignetting using a monitor that underscans or your editing software.
Old March 13th, 2007, 07:29 PM   #5
Thanks for the feedback. I'll do some tests this week. I haven't used that polarizer for several years.
The next step is to look into using those Canon EF lenses I have...But that's another topic!
