Advice on B Camera to shoot w/ Z1 at DVinfo.net
Old December 11th, 2006, 12:21 PM   #1
I have a shoot in Feb 2007 and I will be shooting in HDV with the Sony Z1.
I want to have another camera for behind the scenes and maybe some B roll.
Small form factor and cost are an issue, but I am more curious how these cameras would look with edited footage. Prefer to have similar quality, small form factor and <$2k.
Post will be from HDV tape to FCP.
I am thinking about the new Sony HC3, but it only has 1 - 1/3" CMOS.
What about a FX1, A1U or Canon's HV10?
Thanks, Brian
Brian Scott Fitzgerald is offline   Reply With Quote
Old December 11th, 2006, 12:26 PM   #2
Sony A1 should fit the bill, in decent light, but NOT IN LOW LIGHT!!!
It is a stop and a half slower than the Z1, and degrades horribly in low light compared to the Z1.
Martin at HeadSpin HD on Blu-ray
Martin Mayer is offline   Reply With Quote
Old December 11th, 2006, 12:27 PM   #3
Hello,
The FX1 would certainly match up with it.. The guts and glass are identical.. Now audio may be a problem, as the FX1 does not use pro xlr inputs, but with an adapter like a Beachtek.. it should be fine..The Z1 just has more shooting modes and bells and whistles.
Mike Moncrief
Mike Moncrief mikemoncrief@gmail.com
www.themikemoncrief.com
Mike Moncrief is offline   Reply With Quote
Old December 11th, 2006, 01:07 PM   #4
Agreed with other postings.
I have two A1U's that I use for certain shots only, but never in low-light as it is extremely grainy and can barely hold focus.
To match a Z1U, the obvious answer would be to use another Z1U. Otherwise, I'd go with a FX1, but that'd be about it. You will see a huge difference between the Z1U and anything else, except the FX1.
I use multiple Z1U's as I never have to worry about extensive correction or otherwise.
Marshall Levy is offline   Reply With Quote
Old December 11th, 2006, 04:27 PM   #5
Hi
Agreed, I use a Z1 with an FX1 for second camera. Using the FX1 will save you some headaches and time in post.
Gary
Gary Mckinstry is offline   Reply With Quote
Old December 12th, 2006, 06:16 AM   #6
I opted for an FX1 as a backup for the Z1. All other Sony offerings have different sensor technologies, so if you want to interchange footage, the Z1/FX1 is as close as you'll get. You asked for a smaller, mobile? camera, so the XLR inputs won't be an issue if your microphone is on-camera as the connection wire will be short.
A cool bonus is that you can buy an extended warranty from the Sony store even when you've purchased the FX1 from another source. I bought the extended warranty, which covers accidental damage and product replacement. It's only a little more than than the Mack warranty and is transferrable to another owner. Just imagine how much easier it will be to sell your FX1 with that warranty. Also, if you break the FX1 after a couple of years, you'll get the latest camera in that price range as a replacement (or at least so Sony promises).
I tried to get a Sony store warranty for the Z1. The staff tried for a few days to get me the warranty, but nothing came through. At least I tried.
Gints Klimanis is offline   Reply With Quote
Old December 12th, 2006, 08:16 AM   #7
I tried to get a Sony store warranty for the Z1. The staff tried for a few days to get me the warranty, but nothing came through. At least I tried.[/QUOTE]
>>>>>>>doesn't surprise me with that because the Z1U is considered a professional camera whereas the FX1 is in the prosumer line, hence the reason you can buy it from Sony stores :)
Old December 12th, 2006, 09:37 AM   #8
A1 is classified as a pro camera by sony as well(audio xlr's ), but I'm a little hesitant to use as a Z1 B camera outdoors until I shoot some tests.
Chris Li is offline   Reply
