Z1 Footage is 1440x1080 but why still is 1920x1080? at DVinfo.net
Old December 8th, 2006, 12:51 PM   #1
My vegas timeline says 1440x1080 but when I save a frame capture within Vegas 7 at "Best/Full" then open it in Photoshop and look at the size it says... 1920 x 1080... why???
Carl Downs is offline   Reply With Quote
Old December 8th, 2006, 12:57 PM   #2
Carl,
I don't have Vegas, but from what you describe, it must have scaled the frame horizontally from the 1440 pixels (which is the standard for 1080i HDV) up to 1920 pixels in order to make the pixels square. Photoshop can deal with non-square pixels, but a lot of graphics software can't do this.
- Martin
Martin Pauly
Martin Pauly is offline   Reply With Quote
Old December 8th, 2006, 12:59 PM   #3
Interesting, Carl. When I do a frame grap in Premiere, and I open in Photo shop, I actually get a 1440 x 1080 nominal image that is distorted, and that I have to resize to the 1920 by 1080 to get a distortion free image. I think it has to do with the pixel aspect ratio, and the way they are converted. The Vegas output is probably converted properly.
Chris J. Barcellos
Old December 10th, 2006, 02:49 PM   #4
When i put hdv footage into after effects i always use 1920x1080 square pixels
1440x1080 16x9
1920x1080 square
Stick Tully is offline   Reply With Quote
Old December 10th, 2006, 10:16 PM   #5
Originally Posted by Stick Tully
1440x1080 16x9
1920x1080 square
Actually, both frame aspect ratios are 16x9. With 1920x1080, the pixel aspect ratio is 1:1 while 1440x1080 is 1:1.333.
Mark Utley
Mark Utley is offline   Reply
