Thread Tools
Search this Thread
Connecting Z1...
What is the deal with the Z1 and its inability to be recognized by computers?
I have used 2 different Z1 cameras and both have a hard time being recognized by my computer via firewire. Once in a great while the cameras do get recognized but the inconsistency in ridiculous. I browsed through similar topics and I have Win XP SP2, I have it set to VCR HDV, and downconvert off, restarting my CPU doesn’t work. I even tried downconvert on and other combinations but none seem to work consistently. I would appreciate any advice on this issue? Thank You |
#2 | |
What happens if I push the 'Red' button? |
I'll give it a go on another CPU. I just a little surprised because I have never had a problem like this with a DV cam.
I've never seen any Z1 issues on the Mac platform. I suspect this has more to do with Windows drivers and/or your NLE software. The fact that two different cameras gave the same results with your computer would seem to reinforce that theory...
#5 |
Never seen an issue on the PC platform or Mac platform, either one. I'd look at cable or NLE issues as well.
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
#6 |
With my WinXP SP2 system, the only times I've had that issue, I've found one of the settings to be off:
For HDV- Camera has to be set for HDV firewire output Need to have an HDV project open in the NLE (Premiere Pro in my case) Need to have the appropriate Device Control setting in the NLE For DV Camera set for HDV>DV firewire output DV Project in NLE Appropriate Device Control setting I switch back and forth between HDV and DV projects and occasionally get the "no device online" message when I open the capture window. It is always been due to a left over setting in the wrong format. I have a Z1, a Sony A1U, and the M15U deck. None required any driver installation or other special attention, and all have worked reliably with my system from day one. Hope this helps. |
#7 |
It happened to me when I first connected the Z1U to my desktop (older AMD PC) running XP with no service packs whatsoever and PPRO 1.5. Had to google a little utility that took care of it.
My Sony Vaio Intel P4 laptop (XP with service packs up to date and PPRO 2.0) took it first time I connected it, no questions asked. |
