Gain, How much do you use?
G'day
I have been experimenting with the Gain settings. I always use the Z1 in manual mode, and I have set the Gain switch to: 0, 6. 9 db. But have just had to film in some tunnels and used 12db, I was amazed how little noise there was. What levels do you guys go to in Broadcast situations ? Thanks |
Hi Mark
I've used 12db with good results... everyone harps on at how good the PD 170 was in low light.. but I find the Z1 almost as good at 12db...and you get a 16:9 picture.. I've not pushed as far as 18db which does get grainy..but if it's that or nothing???... cheers Gareth |
i had the gain on auto yesterday and i didnt realise my fx1 had stuck it up to 18, it looked horrible!
I shoot a lot of concerts and usually use 18db gain. It doesn't look bad at all when downconverted. There have been times at the main venue I shoot at when we've turned the lights up a bit (making things slightly uncomfortable for the band) and I've been able to use 15db, which I've found makes a pretty significant difference in noise.
This footage airs every week on a local TV station. I think it looks fine considering the shooting environment. The only other option is dark video.
Mark Utley |
#5 |
My experience is that the Z1 is fairly clean up to 9db then I start to notice the noise.It really depends on the shooting situation whether I worry about adding a little noise. .
#6 |
I was shooting at a concert the other week with the z1 on 12 db's of gain, the picture looks pretty good, and i was only shooting straight DV for the client.
#7 |
In Auto Expoure, is there a way, as with certain cameras, to see the settings, that the camera, would choose. Then perhaps use them, as some sort of exposure guide to set your own?
I know with my old XL2, you could press the expoure lock, and read what the Auto settings were set at. I know you can see the settings during playback, but then it's may be too late. I think the answer to this queston is no! But thought I might ask anyway! Thanks, Mike. |
#8 | |
#9 |
I guess your final format should be your guide to your db settings.
I had a lot of luck with down-converting the footage shot in HDV (12 and up db) to sd (it shrinks the noise just the same), but it's a different story with HD, things can get messy. As a general advise I would not go higher then 9db. Test it in extreme conditions and view it on HD monitor. That's mine two cents Cheers Albert Rudnicki www.yayofilms.com |
#10 |
Gain
i always have my gain set to 6dBs when i'm inside and 0dBs when i'm outdoors...
I'm in love... With my Panasonic AG-DVX100B. Triple M. |
#11 |
I use 12db regularly for shooting events with good results. Definitely correct that anything past 9db will have some noise but depending on where the destination for your video is, it may or may not be an issue. I own a PD170 and a Z1 and have been happy with the Z1's comparative performance. It's not as good of course but definitely good enough.
John |
#12 |
Thanks Guys,
I have done some experimenting with HDV and DVCAM and have come to the conculsion that I will change my settings to: 0,9,12 My reasoning being that under normal conditons 0, is appropriate, If I need more light 9, is vertually undetectable, so why not have the stop? I can always use 12, if I do not want to be wide open and need that extra stop and depth of field. Thanks for all your imput |
#13 |
i use an m2, and i find 9db undetectable and 12db very usable. 15db only used when absoluteyl necessary
