Any gotchas using Step-down adapters? at DVinfo.net
Old September 7th, 2006, 11:45 AM   #1
Hi,
I'm considering getting the Raynox DCR2020 2.2x teleconverter, with a 72->62 step down adapter. The Century 1.6x lens is quite a bit out of my price range. Would the results of using an adapter ring with the smaller lens thread be acceptable? Would vignetting be a problem? Any things to look out for when stepping down to a smaller lens thread size?
Matt
Matt Vanecek is offline   Reply With Quote
Old September 7th, 2006, 12:36 PM   #2
See the following. Evidently that lens will vignette even at full telephoto zoom. Unfortunately I think the Century is the only viable option if you want decent quality. I realize the other brands are cheaper, but that doesn't help much if the quality is unacceptable....
http://www.dvinfo.net/conf/showthread.php?t=66234
http://www.dvinfo.net/conf/showthread.php?t=58525
http://www.dvinfo.net/conf/showthread.php?t=56484
Old September 9th, 2006, 12:34 PM   #3
I use a 72 > 67 mm to use my Canon C8 1.4x telephoto converter on my Z1 and all is well. I can't zoom back far but so what? I bought it to claw back the telephoto reach I lost after selling the VX2k.
tom.
