Weird lines from FX1 capture - need help at DVinfo.net
Old August 6th, 2006, 12:17 PM   #1
I captured using the FX1 and Vegas, but I noticed interlacing lines that are quite apparent on the actor's face even when she is not moving. It looks like scan-lines. Is this the camera? Is there a setting that I have done wrong?
David Delaney is offline   Reply With Quote
Old August 6th, 2006, 06:50 PM   #2
How did you capture it? How are you viewing it? How did you shoot it?
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old August 6th, 2006, 08:00 PM   #3
Shot it during the day, 16:9, FX1. Captured using Vegas and viewing it on a monitor. Also I am noticing a grid-like pattern on most things that are on the screen. IT is almost like a thin-film screen has been put over the footage and I see the little grids on everything!
Old August 9th, 2006, 03:12 PM   #4
I suggest that you redirect this question to the Vegas forum.
Steven Gotz
