Stupid resolution question at DVinfo.net
Old July 23rd, 2006, 08:26 PM   #1
Really simple question. How does the HDR-FX1 film 16:9 video? I have read that it only films 1440 X 1080i but that is 4:3. Does it extract the middle area or stretch the image or does it film 1920 X 1080i? The only reason I’m asking this question is because I don't own an FX1 but I will be using one in a month to do SD slow mo effects for a movie (yes it can be done). Thanx for the help in advance.
Alan James is offline   Reply With Quote
Old July 23rd, 2006, 08:35 PM   #2
The number of recorded pixels is 1440x1080, where each pixel represents a non-square part of the image which gets stretched during playback to produce a proper 16:9 output. Same concept as how widescreen DVDs use 720x480 pixels to represent a 16:9 image. During editing you have to make sure the software understands how to interpret the non-square pixels properly at either HD or SD resolution. Hope that helps.
Old July 23rd, 2006, 08:43 PM   #3
It does help a lot. That’s the exact answer I was looking for. My new question is what is the resolution if converted to square pixels. My XL2 films at 720 X 480 non square widescreen pixels but in square pixels it is 864 X 480. Does the FX1 convert to 1920 X 1080? Thanx for the fast response by the way.
Old July 23rd, 2006, 08:48 PM   #4
Yes, that is how it looks with square pixels on a 1080i HDTV or when exported to square pixels for some graphics program other than Photoshop. You see, Photoshop handles non-square pixels.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old July 23rd, 2006, 10:04 PM   #5
MPS Digital Studios
Non-square pixels is right, which means you get the nice 1920x1080 look on an HDTV. Both the FX1 and Z1 do this.
heath
My Final Cut Pro X blog
Old July 24th, 2006, 05:01 AM   #6
I don't know how you were planning on going about post production, but you can get 60p out of a 1080i clip in a DV project.
Mark Utley
Mark Utley is offline   Reply With Quote
Old July 24th, 2006, 05:40 AM   #7
Just a little nitpick there... with square pixels 16:9 literally means 16 divided by 9 or 1.778. Now 1.778 x 480 = 853.44, but since you can't have a fractional pixel it is usually considered 854. So NTSC SD 16:9 would be 854x480. But this isn't necessarily related to the size of the camera's sensors. Your XL2 has 960x480 CCD's... see the following for more information: http://www.dvinfo.net/canonxl2/articles/article06.php
IIRC, the CCD's on the Z1 and FX1 are actually 960x1080 just to further confuse you :-) BTW, 1440x1080 is actually an HDV standard, and not just something that Sony came up with.
Old July 24th, 2006, 07:37 PM   #8
Yes you are correct about the square pixel thing, however all widescreen DV cameras use non-square pixels with a width of 1.2. If you take 1.2 and multiply it by the 720 horizontal square pixels it has on a tape you come out with 864. When I open after effects and select this setting (square pixels 480 X 864) it fills the entire frame without any running over the sides like it does on a setting with 854 pixels. Mark I don’t know if you meant to put “can’t” or if you are telling me that I can do what I already know is possible to do. If it is cant then ill explain in case you are interested in doing it yourself. A 60i camera films 60 frames a second. These frames are half frames composed of either odd or even lines. In normal SD video that would mean that they are 240 pixels tall. In after effects you can tell it to separate the fields and alternate between odd and even thus create a slow mo effect, but because its only 240 lines it looks bad. SO… if you use HD you get 540 lines and when that’s converted to the normal 480 lines of SD it looks great. You can’t tell a difference. However this would be for another post. If anyone wants to know exactly how to do this then start a post about it and I’ll explain how. (I also think it might already be somewhere on this site……somewhere.)
Old July 29th, 2006, 08:38 PM   #9
Just to make sure this is clear: The physical pixels are not square. The sensor is 16x9.
Dale Connelly is offline   Reply
