FX1 - should I be looking at the DVX? - Page 2 at DVinfo.net
Old July 23rd, 2006, 07:18 PM   #16
MPS Digital Studios
1. Do a de-interlace and you should get a 30p look with 60i.
2. Use a DI (Direct/Digital Intermediate) to edit native .m2t files (mpeg2-ts), like CineForm's products (PC-only).
I HIGHLY recommend grabbing a copy of the latest edition of VASST's HDV: What You NEED To Know book (volume 2):
http://www.vasst.com/product.aspx?id...0-0ad68139e940
We talk a lot about the HDV cameras, including the first JVC cams, and a bunch of different workflows with all kinds of NLEs, including proxies for PCs and Macs. And, of course, we cover software like Nattress and Film Maker (but not Magic Bullet, sorry).
heath
My Final Cut Pro X blog
Old July 24th, 2006, 03:53 AM   #17
Heath,
Thanks. What you're suggesting is to use the film maker program as opposed to Mb for deinterlacing?
I'll take a look at the vast book.
Bruce S. Yarock
Bruce S. Yarock is offline   Reply With Quote
Old July 24th, 2006, 08:08 AM   #18
MPS Digital Studios
I haven't used Magic Bullet, that's what I mean. If you're on a Mac, I like both DVFilm Maker and Nattress. For PCs, I like Maker. I hear Magic Bullet is excellent.
hwm
Old July 24th, 2006, 08:25 AM   #19
Heath,
We're on pc with Premiere pro. We'll try both MB and film maker.
Bruce S. Yarock
Old July 24th, 2006, 08:32 AM   #20
MPS Digital Studios
And make sure you're using a DI when capturing. Sure, a different flavor of HD can increase disk size, but it's so much easier to edit than native HDV/m2t.
Try AspectHD for free:
http://cineform.com/products/AspectHDPPro.htm
Try DVFilm Maker for free:
http://dvfilm.com/maker/index.htm
Not sure if you can try Magic Bullet for free:
http://www.redgiantsoftware.com/magicbullet.html
heath
Old July 24th, 2006, 04:24 PM   #21
Originally Posted by Heath McKnight
Some tips when using HDV:
I usually shoot in 50i with CineFrame 25, edit, convert it to an uncompressed HD codec (photojpeg, 75% quality in Final Cut Pro) and then make it a QuickTime movie (NOT a conversion). I then conform it to 23.98 fps in CinemaTools and re-import into FCP and then into a 23.98 timeline/sequence. I then add music and color correct. This is a workflow developed by Graeme Nattress.
heath
Thanks for all the really specific work flow information, tips and know how!
One question (hopefully not to dumb); in converting the 50i to uncompressed HD codec (photojepeg, 75% in FCP) - this process is done in FCP or do you use nattress or dvfilmmaker to convert it?
Duane
Duane Harper Grant is offline   Reply With Quote
Old July 24th, 2006, 11:34 PM   #22
MPS Digital Studios
It's in Final Cut Pro. When you're finished cutting, simply copy the project and open up a new timeline. Set it to 50i and then change the QuickTime settings under Sequence Settings to Photojpeg and the quality to 75% (this is not dropping the visual quality, just the compression from 10 bit, or 100%, to 8 bit, or 75%). Then File, Export, QuickTime Movie (NOT conversion).
hwm
ps-This is if you shot with CineFrame 25 on; if not, use a good de-interlacer.
Old July 25th, 2006, 05:09 AM   #23
Thank you Heath!
As a dv newbe it's good to have a viable workflow for CineFrame25.
Old July 25th, 2006, 08:52 AM   #24
MPS Digital Studios
Thank Graeme Nattress who came up with it!
hwm
