Z1 manual, p.71 warning?? at DVinfo.net
Old June 3rd, 2006, 02:08 AM   #1
In the manual for the Z1, on pg. 71 it says "if you record in the dv sp mode, a mosaic-like disturbance of picture may appear or sound may be interrupted when you play back the tape on other camcorders or VCRs."
What does that mean? Are they saying that if I shoot in dv sp mode when shooting 2nd camera for someone who requires dv sp, and hand my tape to them, they may not be able to play it without my Z1?
Or does it mean something else because it's in the section for "Using the IN/OUT Rec Menu" Maybe it means this might happen only with tapes you record in VTR mode???
Chris Gorman is offline   Reply With Quote
Old June 3rd, 2006, 10:23 AM   #2
I have an FX1, so I dont think it appears in my manual... had a look.
But, from what you posted, I take it to mean that, yes, if you record in dv sp, then give it to someone else, it *might* be a little screwy.
Leo Pepingco is offline   Reply With Quote
Old June 3rd, 2006, 10:52 AM   #3
this warning i have seen in many DV camera's manual.
It means:
Every camera, altho using DV format/spec, have slightly different head design. More different if the manufacturer is diff. eg. sony vs jvc.
So, your DV recorded material, may not playback smoothly if played using other maker/model DV player.
i have personnaly encountered this problem, playing a miniDV from a old sony camera, in another type DV player (also sony, newer). I thought the tape was scratch/broken, but when i play again in original camcorder, the picture is fine.
so, different head design may not be compatible for your recorded material.
Hornady Setiawan is offline   Reply With Quote
Old June 3rd, 2006, 03:00 PM   #4
I don't see the logic in any of this.
I use the Z1 (and FX1) professionally for broadcast work in the UK and so at the end of a shoot I have to give my tapes to the producers to take back to the edit suite. I've never had to give them the camera as well - neither would I expect to...
We always expect our tapes to play out on any machine.
Robin
Old June 3rd, 2006, 03:34 PM   #5
BTW: The warning is on p.72 (not p.71) for the Z1E/Z1P ("PAL") version owners looking for it.
Martin at HeadSpin HD on Blu-ray
Martin Mayer is offline   Reply With Quote
Old June 3rd, 2006, 09:28 PM   #6
My guess is that it may be a typo. Perhaps they meant LP not SP.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old June 4th, 2006, 03:32 AM   #7
Robin
Try playing a Z1 HDV tape on the XL-H1. Or vice versa. Then you'll see the logic. Altho both use HDV format, the different head design may not record exactly the same electrical signature on the magnetic tape. The difference is microscopic & minute, but it is there. You may experience block noise/dropouts because of this. DV LP mode is more susceptible for this type of problem since denser recorded signal.
The warning was just a disclaimer if you encountered something like above.
And of course, Z1 tapes will play fine on M1 players, since the head design is the same. Otherwise Sony wouldnt release them as cam & vtr siblings.
I read this kind of warning (disclaimer) in HVR-A1 & HC-3 manual also.
Old June 4th, 2006, 04:08 AM   #8
Well, the discussion started about playing back in the DV mode, which is the format I use (even with the Z1), because that's what the broadcaster wants.
I wouldn't know about the incompatibilies of HDV - although a standard is a standard etc. etc.
Robin
Old June 4th, 2006, 06:28 AM   #9
I thought so too, however I looked at the original Japanese manual and it has the same information.
I can't believe they made the same typo in both Japanese and English.....
I was produced in Scotland, edited in Sweden, and am now showing in Japan.
http://www.gaijin-eyes.com
Douglas R. Bruce is offline   Reply With Quote
Old June 4th, 2006, 06:28 AM   #10
I may be wrong and don't have any experience with the cameras but I was under the impression that the Z1 and FX1 record using the DVCAM specs instead of standard miniDV when in SD mode? At least that's what the specifications in the back of the manual state. Perhaps that's the reason for the warning as some miniDV decks and cameras have problems with DVCAM format tapes.
Old June 4th, 2006, 08:17 AM   #11
No. The Z1 has three recroding choices - HDV, DV SP and DVCAM. The FX1 (and the HC1) have a different 3 choices - HDV, DV SP and DV LP.
Colin Pearce is offline   Reply With Quote
Old June 4th, 2006, 12:14 PM   #12
My take on this is a little different... I think they may be trying to say you should use DVCAM to record standard definition, because that way you would need to buy a Sony deck or camera to play it back not to mention the fact that you'd use 50% more Sony tape ;-)
Old June 4th, 2006, 06:48 PM   #13
Spot on - and just to clarify, DVCAM was 'invented' to tidy up the compatibility issues of DV between camera and deck - especially those decks that get hammered in a professional environment. Faster speed made for wider track spacing, and a little more slack in the acceptable accuracy stakes.
My old PC-7's manual warned that if recorded in Long Play mode, only my PC-7 would reliably play it back.
Old June 4th, 2006, 07:32 PM   #14
yes, a standard is a standard...
yet early adopters of a standard, may not 100% compatible with other makers, altho using the same standard.
we rarely see this problem Now in DV standard, but in early days of DV, this problem happens, especially in LP mode...
Now is early days of HDV, so, expect incompatibilities out of different makers. Z1's head design is new, to conform to HDV, yet it is also designed to be compatible with DV, that's why they put the warning, that's why we see this warning in the new HDVs also like HC3 & A1, because their head design is the same, and may not be 100% compatible with other brands.
Not only in HDV, but in other new standards like: HD-DVD format, MPEG4 / WMV desktop players, new standards are prone to incompatibility.
Old June 6th, 2006, 01:59 PM   #15
MPS Digital Studios
I looked at the manual, and it seems to talk more about mixing DV and DVCAM (and HDV) on one tape, that can cause problems. If you're shooting in multiple formats on the Z1, use different tapes.
heath
My Final Cut Pro X blog
Heath McKnight is offline   Reply
