Using 2 mics with the Sony HVR cam? at DVinfo.net
Old May 25th, 2006, 02:31 AM   #1
I need to use 2 mic input on my Sony HVR Z1. First mic being a radio mic which will be on the host of a seminar we are shooting with 40 people in a room which i have used before but also I want to use my shotgun mic so that my assistant can be the roving mic within the audience. Can I conect both mics to the camera and record them on seperate audio tracks so that when I input the film and audio into Fincal Cut Pro I get 2 seperate audio track to edit?
Hope someone can help
Allister in Scotland
Thats not the way the world works!
Allister Gourlay is offline   Reply With Quote
Old May 25th, 2006, 06:17 PM   #2
Short answer - yes.
Slight clarification - in the Audio setup menu, there's a point at which you select either Ch1 or Ch1,Ch2. You need (perversely) Ch1 - the other option records Ch1's input to BOTH tracks. If you're having difficulties, this is probably where they originate.
With that sorted, you'll have no problems. A lot of my work involves recording content at conferences, where I take a line feed from the sound desk onto channel 2, and pick up audience noise from a rifle mic on channel 1 (otherwise we'd never hear the audience response!). In FCP during ingest, each track is treated separately - e.g. C1, C2 not a stereo pair, but you can always do a Ctl-L (sic) to link/unlink the tracks.
BTW, SoundTrack Pro has got a great stereo thingy that takes a mono input and (subtly) spreads the frequencies over a stereo field, livening up your soundtrack (especially audio from wide shots) a great deal.
Old May 25th, 2006, 08:12 PM   #3
I was wondering if this is also possible with an FX1 and a beachteck.
Leo Pepingco is offline   Reply With Quote
Old May 30th, 2006, 09:44 PM   #4
MPS Digital Studios
Should be okay on the FX1. I haven't used one with Beachtek in a while though.
heath
My Final Cut Pro X blog
Heath McKnight is offline   Reply
