Z1U - Different Mic Mount? - Page 2 at DVinfo.net
Old May 18th, 2006, 09:12 PM   #16
Rextilleon
Hi, I am using a Professional Sound Corp shock mount (59 bucks at B&H) with an extension that raises it slightly above the built in light shoe---It works great---no thumbing or other disturbing sounds.
Red #97
David Mintzer is offline   Reply With Quote
Old May 21st, 2006, 10:25 PM   #17
Another option maybe - http://www.thej-rod.com/ At $50 it's almost cheap enough to buy just to try. Nice simple design too, almost looks like it belongs there. Anyone seen one of these in use?
Brendan Dunn is offline   Reply With Quote
Old May 22nd, 2006, 12:26 AM   #18
Canon for Z1
B&H sold me a Canon mount that works perfectly on the Z1, raising the mic (with a rycote furry) on an ME66 high enough so even when I use a wide angle it is not in the shot. It is the lightwave MM XL1 mount. Cost $125.
bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=167170&is=REG&addedTroughType=categoryNavigation
It fits in the Z1 mic clamp like a OEM product. Haven't tried the others but this solved my problem of having the furry hang in the upper part of a Y angle shot.
Jack D. Hubbard is offline   Reply With Quote
Old May 23rd, 2006, 01:44 PM   #19
Jack - that's the missing link - placing order next week - how that's ME66 mic? Suspect I'll end up with the same rig you have.
George
George Yousko is offline   Reply With Quote
Old May 24th, 2006, 01:26 AM   #20
If you have the K6/ME66 in a Rycote Softie, the isolating rubber mount (comes with the Rycote) holds it all well clear of the lens, even when fitted with a 0.5x wide-angle converter.
Or am I missing something here?
tom.
Old May 24th, 2006, 10:16 AM   #21
Lightwave
George,
The Canon XL lightwave will fit in the existing mic holder for the Z1 It is rugged and adaptable, will carry a rycote and won't shear off. I have never had a problem, and it was worth the $125 from B&H. And better balance, leaving the shoe for either a mic or a light.
Jack
Old May 25th, 2006, 05:54 PM   #22
Me66
Hi George,
Forgot to tell you about the ME66. It has been very good. There is a lot of discussion and comparison of this mic with the 67, 416, Azdens, etc. It is a good workhorse shotgun mic. I use it inside and outside; needless to say it is better outside. I have been watching the mic trim a lot in the Z1 menu, because you can make some pretty significant adjustments depending on the ambient sound environment.
Jack
