I need help finding a good tripod! at DVinfo.net
Old April 30th, 2006, 12:33 PM   #1
I've read other posts on this topic but the answers didn't seem to help...
I’m in the market for a good TRIPOD for my Sony-HDR-FX1 and Beachtek DXA-FX Audio Adapter. I’m looking for very fluid motion. This tripod will be used outdoors a lot for my narrative film in different weather so I’m looking for something pretty sturdy!
But, I don’t have a lot of money and $450.00 is my limit! I’d prefer to spend less but I really don’t know what to buy or to expect. Am I being unrealistic at that budget limit? Should I buy different parts from different companies? Where to buy and what to get? It’s all so confusing!
William N Zarvis is offline   Reply With Quote
Old April 30th, 2006, 12:43 PM   #2
For the size of your cam and your needs at about 450 bucks, try looking at the bogen/manfrotto 503 head. Then stick the sticks you can afford under that head. At least that way you will get the value where it's needed: Slick smooth pans and tilts.
Jimmy McKenzie is offline   Reply With Quote
Old April 30th, 2006, 01:04 PM   #3
Jimmy - I'm in the same boat as you. I've been shooting on a DSR300 for the last 5 years and recently picked up a Z1 and need a tripod for it
I have bogen 3046 legs with a 516 head for the 300 but the spring is to tense to handle the z1 and kicks back on the tilt bigtime.
I am stuck because I need the "center geared column" on the 3046 badly and no other tripod really provides that except for a few Gitzos and some really high end pods out of my budget.
I am probably just going to get another 3046 with a "503" head. I've seen that combo before - and its a good cost effective and quality solution. The two units are not half balls - just flat.
This is about $474 - and a pretty solid setup.
http://www.bhphotovideo.com/bnh/cont...=309002&is=REG
You other option is to go to a ball head/legs
You could go with a 3460 legs and a 503 head for about $459.00
http://www.bhphotovideo.com/bnh/cont...goryNavigation
Or the 3181 with 503 head for about $494.00
Just a few thoughts :) I am actually finding that getting the right tripod is more of a pain then the actual camera. At least with the camera you have like 3 choices - tripods - thousands. :(
Paul
Paul Dhadialla is offline   Reply With Quote
Old April 30th, 2006, 02:13 PM   #4
I'm saving up for a Vinten Vision 3. It's expensive but so worth it.
http://www.bhphotovideo.com/bnh/cont...ughType=search
Mark Utley
Mark Utley is offline   Reply
