Does HDV = 4:2:2 SD? at DVinfo.net
Old April 9th, 2006, 03:51 AM   #1
I've seen various technical discussions on this which go right over my head, but I want to know, if I downconvert 1080i HDV to a 4:2:2 SD codec like DVcPro 50 or Canopus, will I get full 4:2:2 colour from th FX1 in standard def?
John Poore is offline   Reply With Quote
Old April 9th, 2006, 06:48 AM   #2
Pretty much: effectively HDV stores the color information for a group of four pixels, and when you scale down to SD from 1080i you're cutting the pixel count by about 75%. So absent compression issues, you'll actually have more color information than shooting native 4:2:2 SD; a smart scaler could probably use the extra luminance information to give you ten-bit video as well.
Mark Grant is offline   Reply With Quote
Old April 9th, 2006, 07:27 AM   #3
The next question is, would the same apply to an FX1 or Z1 shooting in DV mode?
Or is it the ability to just pull more info out of a HDV image?
Leo Pepingco is offline   Reply With Quote
Old April 9th, 2006, 09:19 AM   #4
Thanks for the reply Mark. I thought it was something like that given the amount of info on 1080i. Some of the tech discussion are v complicated.
Old April 10th, 2006, 04:40 AM   #5
No. DV25 is always 4:1:1 or 4:2:0.
