QR-PD170 Gold Mount Battery at DVinfo.net
Old March 31st, 2006, 11:54 PM   #1
Anyone ever put this on their camera, its made by Aunton Bauer to mount a brick battery on the camera, I was wondering if anyone used it, if its worth it? Does it mount on the back of the camera or on the bottom. No info seems to be on the net.
Mack Fisher is offline   Reply With Quote
Old April 9th, 2006, 09:21 AM   #2
this particular mount has the ac connector for the camera, and NOT
the battery blank. I called Anton since I wanted to use this for my
Z1, and they custom made me one of these with the faux battery,
with the powertap for an ultralight. Cost $250, but well worth it.
Scott Hayes is offline   Reply With Quote
Old April 9th, 2006, 10:19 AM   #3
I also don't think it is for the NP1 brick but for the Dionic90 or Hytron 50 either of which will power a PD170 for hours and hours and hours plus you can use a light with a power tap on it (AB Ultralight or similar)
It is an External Battery pouch which means the power line runs to the camera and the battery mount and battery fit into a pouch that is seperate from the camera-I think it attaches to your belt
QRPDHDV Pouch-Style Battery Plate - for Sony FX-1 and Z1-U Camcorders
Mfr Catalog # QRPDHDV (will also work with the PD170)
Don
Old April 10th, 2006, 11:32 AM   #4
I run a Hytron 50 on my belt with my Z1 and it's fantastic.
Brilliant Champions | Gallery Hijinks
Joe Lumbroso is offline   Reply
