Contributor
3.2X telephoto for the Z1U/FX1
Based on a "recipe" for combining telephoto adapters posted by John Jay in this thread:
http://www.dvinfo.net/conf/showthread.php?t=51686 I decided to try a combination of a Century 2X tele-adapter used on my PD150 and a Century 1.6X tele-adapter used with my Z1U. You can see the combination mounted on the Z1U here: http://www.clamcamvideo.com/telephoto.html along with frame grabs taken with each of the combinations. In summary, center-field imagery with the combination seems to be quite good. Carroll Lam |
It looks to be good outside lighting Carroll, so can we assume you used both internal NDs and something like f/4? Just wondering if some of the edge nasties can be cleaned up by switching off one of the NDs and shooting at f8 or so.
I find shooting perpendicular to brick walls better than trees. The latter wave in the wind and disguise any linear distortions. tom. |
BTW, there's some nice lenses here. I've been impressed with the Raynox lenses I've tested.
http://www.raynox.co.jp/english/dcr/egindex.htm |
Contributor
The images were quick shots to get qualitative info so all the collection parameters were not recorded.
It was outdoors so probably at least ND1 was activated. The f-stops ranged from 5.2 for the Z1U lens alone to 6.2 for the add-on combos. I expect to collect more quantitative and variational data soon. I live in Tucson, AZ so most of our walls are adobe not brick. 8-) Carroll Lam |
#5 |
Hey Carroll,
If you play back the footage in your camera and press the Status Check button, it should tell you the exact settings you had.
Mark Utley |
#6 |
raynox telephoto
Tom Hardwick - can you post more on your experience with the two raynox lenses, the good and the bad? I need to pick up a telephoto and the Century is out of my range for now ....
thx! |
#7 |
The two Raynox lenses I've tested are the 6600 Pro and the 0.5x snap-on wide-angle converters.
http://raynox.co.jp/english/video/egwidehdxl.htm The 2.2x telephoto is shown here: http://raynox.co.jp/english/video/hdrfx1/index.htm with comparison shots here: http://www.raynox.co.jp/english/dcr/...exdcr250eg.htm tom. |
#8 |
There is another approach you might try if you already have some good telephoto lenses for still-cameras.
There are people building adaptors of similar principle to the P+S Technik Mini35. I have removed the groundglass from one that I made, for using lenses which have an aperture tighter than f5.6 which are not good for using via a groundglass system. On the PD150 with a 4:3 frame I can get inside the vignette on full zoom with the following combinations :- 7+ Century Optics Achromatic dioptre. Camcorder zoom at 100%. The following lenses on wide-open aperture. Tamron 300mm prime (adaptamatic version ). Nikon 500mm mirror telephoto f8. MTO 1084mm mirror telephoto f11 ( a bit soft, with 2x = very soft). Sigma 50mm - 500mm f4 - f6.3 zoom. (with 2x, a bit soft but acceptable). I fitted the arrangment up to an FX1 but found the 16:9 screen is a bit wide for maximum zoom to entirely eliminate the vignette. I think it can just fit as I have some problems with the arrangement of my design due to the prisms I used to flip the image. If you leave the image unflipped, things are simpler. The image the camcorder sees in back of the lens is upside-down unless prisms or mirrors are added into the path to flip the image upright and right-way about. |
#9 |
Here's a link to footage of the DCR-2020PRO (2.2X) on a FX1.
http://raynox.co.jp/actualimage/vide...20pro-duck.mpg I have not heard a review of this lens but you can see abberation in the demo video. However, you can get one for $188 so it might be worth looking at. I'd really like to see some high-res stills and example footage from anyone who may have taken some with either a Z1 or FX1. http://www.1oel.com/comersus/store/c...efsession=0306 |
