FX1 or Pd170? at DVinfo.net
Old March 9th, 2006, 05:26 PM   #1
FX1 or Pd170?
Which one is better if I'm not going to HDV? SD only
Juan Dela Cruz is offline   Reply With Quote
Old March 9th, 2006, 05:42 PM   #2
This thread is for you :-) http://www.dvinfo.net/conf/showthread.php?t=50112
Old March 9th, 2006, 05:44 PM   #3
For SD only the PD170 will be better in low-light situations, while the FX1 is good for making widescreen SD DVDs. Also, you can shoot in HDV on the FX1 and downsample out of the camera to widescreen DV, so you can edit in SD today but still have your HD master tapes for the future.
Old March 9th, 2006, 06:35 PM   #4
Unless low light is prime issue, FX1 all the way.
Chris J. Barcellos
Old March 9th, 2006, 06:41 PM   #5
dvx100b?
other camera capable of true 16:9 SD? XL2 only?
Old March 9th, 2006, 06:46 PM   #6
Sony PDX-10. It appears this has just been discontinued, but still available from B&H Photo for $1,700. Low light may be an issue - perhaps one stop slower than the FX1. Otherwise a very nice camera for that price. See our forum here: http://www.dvinfo.net/conf/forumdisplay.php?f=43
Old March 9th, 2006, 06:49 PM   #7
Hc1
Does all HDV camera have true 16:9 widescreen in SD like the HC1, HC3 and A1?
Old March 9th, 2006, 06:57 PM   #8
High Definition video is 16:9, so that should be a safe assumption. Some of these cameras may not offer 4:3 SD however (not really sure).
Old March 9th, 2006, 07:54 PM   #9
FX1 will shoot SD 4:3 or true 16:9 DV, and very nicely.
Chris J. Barcellos
Old March 9th, 2006, 08:18 PM   #10
Thanks for clarifying that. However, if you shoot HDV and want to downconvert to SD I believe the only option on the FX1 is widescreen. But the Z1 lets you downconvert to widescreen and 4:3.
Old March 9th, 2006, 08:28 PM   #11
In down convert, my menu screen does not appear to give a choice. How does the Z1 handle the 4:3 down convert from HDV? Is it just a crop, or does it sqeeze the image?
Chris J. Barcellos
Old March 9th, 2006, 09:38 PM   #12
With the Z1, you can do either. Your downconvert options are SQUEEZE, LETTERBOX or EDGE CROP.
Mark Utley
Mark Utley is offline   Reply With Quote
Old March 10th, 2006, 06:22 PM   #13
Thank you for info
Chris J. Barcellos
