HD Video sizes per hour at DVinfo.net
Old February 5th, 2006, 05:05 PM   #1
Ive been capturing my 1st few hours of 1080i 50 HD videos and per hour its coming out about 45GB? I was under the impression it was 300 or 400GB; im using cineform 4 with adobe premiere 1.5.1.
Is that about right?
David Dwyer is offline   Reply With Quote
Old February 5th, 2006, 05:07 PM   #2
Well, the Native HDV codec is about 11.25 GB per hour, just a bit less then normal DV.
Vincent Rozenberg is offline   Reply With Quote
Old February 5th, 2006, 05:53 PM   #3
Some details from one of the tapes:
50.2 GB (53,929,878,904 bytes)
Width 1440 pixels
Hight 1080 pixels
Audio
Duration 1:04:43
Bitrate 1536kbps (that low?)
Audio Sample size 16bit
Audio format PCM
Video
Frame Rate 25frames/second
Video Sample Size 24bit
Video Compression Cineform Codec
Old February 14th, 2006, 06:07 AM   #4
That sounds about right for Cineform. About 100mbps on the video (and basically with the audio too). Uncompressed 16bit 48khz audio is about 1.5mbps.
Robert M Wright is offline   Reply
