Just got the Century .6x and 1.6x lenses - Page 3 at DVinfo.net
Old February 13th, 2006, 08:17 AM   #31
120mm
Hey Joe;
First time I've had a recipe named after me, ha ha
following is a short clip with both C-8 attached giving ~120mm or 2.24x
http://s49.yousendit.com/d.aspx?id=3...82572AG05MYGFQ
spot the magpie;
PS; this was taken last year when I was checking out all the BS about HDV not being able to tackle moving water and leaves moving in trees - as you can see there is a lot of movement and no worries.
John Jay
Beware ***PLUGGER-BYTES***
John Jay is offline   Reply With Quote
Old February 18th, 2006, 03:27 PM   #32
Contributor
I didn't notice that I posted the same image link twice!
The image taken with the Z1U's standard lens at maximum zoom is:
http://www.clamcamvideo.com/images/STD.jpg
and the image taken with the Century 1.6X tele is here:
http://www.clamcamvideo.com/images/Tele.jpg
Sorry 'bout that!
Carroll Lam
Carroll Lam is offline   Reply With Quote
Old February 21st, 2006, 04:27 PM   #33
Contributor
Mine's bigger than yours!
John Jay's "recipe" for cascading multiple adapters prompted me to perform the following tests with the Century 2X lens purchased for my PD150 and the Century 1.6X purchased for the Z1U.
The following image is a screenshot taken with the standard Z1U lens at max zoom:
http://www.clamcamvideo.com/Tele-none.jpg
I then added a 72mm->58mm step down ring to the Century 1.6X teleconverter and mounted that on the Z1U and extracted this screenshot from the resulting video:
http://www.clamcamvideo.com/Tele-16X.jpg
Then I replaced the 1.6X teleconverter with the 2X and extracted this screenshot from the video:
http://www.clamcamvideo.com/Tele-2X.jpg
Finally, I mounted the rear of the 1.6X tele to the front of the 2X tele - they match perfectly. (How I kept the two converters together is left as an exercise for the student. 8-) ) Here's the screenshot obtained from the combined assembly:
http://www.clamcamvideo.com/Tele-32X.jpg
Observations:
1. Center-of-field image quality of all the combinations seems to be quite good, at least qualitatively. Or, IOW, all the tele combinations compare favorably to the standard lens. Overall image contrast seems to hold up.
2. There is a modicom of vignetting on the left and right sides of the 3.2X combination but it is soft and not distracting. There also seems to be a little with the 2X converter also.
3. There is only a small amount of zoom (from maximum) that can be done without much more vignetting for both the single 2X converter and the 2X+1.6X (3.2X) combination.
Summary
I would have no qualms about using the two-converter combo if I really needed the "reach" they provide.
My thanks to John for tipping us off to this technique!
Carroll Lam
Old February 22nd, 2006, 09:03 AM   #34
FYI, I just posted a free VirtualDub filter for correcting chromatic aberration (CA) that you all might find useful for correcting the type of CA that Boyd saw in his factory shots. Check out the following
http://www.dvinfo.net/conf/showthread.php?t=61274
Cheers,
Bill
William Gardner is offline   Reply With Quote
Old February 22nd, 2006, 10:15 AM   #35
Contributor
Thanks, Bill!
Carroll Lam
Old February 22nd, 2006, 01:14 PM   #36
Some folks stack three! :):)
http://www.cs.mtu.edu/~shene/DigiCam...Support-1s.jpg
John Jay
Old February 22nd, 2006, 02:03 PM   #37
Contributor
Hey. I'm jealous. 8-)
I am jealous of that neat adjustable lens support arm. I wonder if that's commercially available somewhere or was a custom make?
Carroll Lam
Old February 22nd, 2006, 03:01 PM   #38
I think its a Bogen/Manfrotto gizmo - check their catalogue
John Jay
Old March 25th, 2006, 10:48 AM   #39
On Century's site, why do they only list the .7x and .8x as "HD". Is the glass on the .3x, .6x, 1.6x and others somehow compromised or sub-spec?
Shane Coburn is offline   Reply
