** HELP ** Z1 LCD flips only in Vertical
I've noticed a strange thing.
The LCD of my Z1 when fliped to the front, inverts the image ONLY in Vertical. Not on the Horizontal. Here is a photo taken with my mobile to show the situation: http://www.boamemoria.pt/hdv/lcd_invertido.jpg If I rotate it faces down and restore it to the original position -as described on the manual page 16 (Step 4 Tip)- the image is ok. If I apply an iman the image is also correctly inverted. ONLY if I turn the LCD to the front (set) the image is "half turned". Is this normal on this camera ? Or is my camera broken ? Thanks in advance Carlos Manuel |
Hi there,
IT's normal, I just checked my FX1, same deal. My GL2 also is the same. Nothing to worry about in my opinion. Video will not be affected in any way. Sean
~~~~~~~~~~~~~~~~~~~~~ Sean Hansen CMProductions http://pages.infinit.net/cybrmonk/ Montreal, Quebec ~~~~~~~~~~~~~~~~~~~~~ |
It's for self-shooting, so it acts like a mirror - much easier to line yourself up than looking at a correct camera image. Try it some time and you'll see what I mean. We're all used to seeing ouselves in mirrors after all - except for vampires of course...
Robin |
Thanks for your answers.
I've never shooted myself - I'm an UGLY guy... Maybe it's suposed for me to know this, but I don't know ALL. Still learning. I can understand the concept of the mirror. It's logic. I've "discoverd" this, searching for the place to put the iman to invert the image, dreamming with a Guerilla35. BTW. what do you think about the Cinemek G35 / RedRock Micro35 ? Thank you Carlos Manuel |
