HVR Z1U analog video output display at DVinfo.net
Old November 20th, 2005, 05:01 PM   #1
While shooting out to a separate CRT monitor so that a director could watch the 16:9 & 4:3 safe marks and time code, but when I go into the menu: OTHERS> DISP OUTPUT> V-OUT/PANEL the safe marker and TC display flashes on for just a split second in my CRT monitor and then disappears.
When I press "status check" it only displays the other status pages on the analog video output. Is there some way to keep the entire "lcd viewfinder" display up on the analog video output? I guess maybe they intended this to be a clean analog video output for separate recording.
Drew Kreisler is offline   Reply With Quote
Old November 20th, 2005, 10:41 PM   #2
I believe it's on your remote that you can change this setting. I know for a fact that you can make all the guides and info show up on a TV so try the display button on the remote.
Mark Utley
Mark Utley is offline   Reply With Quote
Old November 21st, 2005, 06:10 AM   #3
Tried it on the remote and the top display button and neither works except for a brief flash of it when you turn the "status check" off.
Old November 21st, 2005, 06:40 PM   #4
will not show if the output is set at 1080i and you are using COMPONENT out.
- shannonrawls.com
Shannon W. Rawls ~ Motion Picture Producer & huge advocate of Digital Acquisition.
Shannon Rawls is offline   Reply
